featherliteCT1 wrote:Nice portable solar panel set up ... Well thought out and executed! Cost effective also.
What brand and model of solar charger are you using?
flboy wrote:featherliteCT1 wrote:Nice portable solar panel set up ... Well thought out and executed! Cost effective also.
Thanks for the battery info. I may go with the Trojan's. I have a battery dealer nearby that sells them. I need 4 total.
The Charge Controller is just a cheapo Chinese made PWM controller. Just about all of them are the same.. just re branded about 20 different ways. They work decent for what they are if you get one that does work. Nothing you'd want as your primary controller. This one was DOA... Not sure why. I opened it up and the workmanship actually was not bad. Nothing obvious from an assembly perspective.
featherliteCT1 wrote:"you have to plug in the output to a good battery before exposing to sun"
I did not know that ... thanks for the tip
Not a question of "best", FLA is **so** much better value $ / AH / year, my advice is to only use AGM if you have a compelling reason to, or are willing to pay lot$ more for a very slight convenience factor.flboy wrote:I am somewhat cost conscious and do not need the best, so I am fine with SLA batteries and have room for 4 batteries (group 29C size). What brand /size would be the best bang for the buck? I have 3 12VDC batteries now with 375aH total.. and I'd like to improve that capacity also to >400aH. Thoughts?
