flboy wrote:The Sterling 30A model does not ndicate how big the battery bank can be.. but I am assuming it makes a difference?
featherliteCT1 wrote:Flboy,
Thanks for all your efforts documenting your electrical system.
Question: Does your Victron monitor display the actual volts of your batteries or does the monitor display the volts as adjusted for battery temperature differences?
I presume your charge controller temperature compensates and adjusts the volts accordingly; however, I am asking about the readout at the monitor. If the monitor does not display the volts as adjusted for the temperature differences, it appears that one would need to go through the effort of using a temperature adjustment chart (like the one you posted a while back) in order to ascertain the true state of charge (e.g., so as not to discharge the batteries below the desired depth of discharge).
Again, I am easily confused and still learning ... slowly but surely.
Thanks again!
albertaborealis wrote:Hi Don
I hope to start my build on a 8.5x20 trailer that has been ordered. I will start my own thread as I get closer to that date. I have been following your posts, along with others, and gleaned a lot of useful information. I liked your solar and electrical set up. I hope to follow it fairly closely. I wonder, since the time you published your schematic, whether you had any thoughts about how you might have done things differently. I can imagine that with time and experience a person sees the possibility of improvements. Thanks again for publishing all the intriguing and valuable aspects of your build.
Richard
