Don & Karen's 6 x 12 Deep Vee Front CT
Re: Don & Karen's 6 x 12 Deep Vee Front CT
Postby MtnDon » Tue Jul 01, 2014 9:25 pm
:oops: most are still in the Nikon... I have just plugged it into the computer. Keep an eye open here... :oops:
MtnDon
Images: 24
Postby MtnDon » Tue Jul 01, 2014 11:29 pm
A few assorted shots. I'm not the greatest photographer.
One of the one nighter FS campsites...
Glacier Basin campground, RMNP. Loop C and D have been devastated by pine bark beetles. When we reserved there were no vacancies in loops A & B (with trees). My BIL's trailer in the background.
from around 12,000 feet...
It was wildly windy up there but the Marmot was sunbathing. :)
MtnDon
Images: 24
Postby MtnDon » Tue Jul 01, 2014 11:33 pm
We hiked over some snow...
seen along the trails...
MtnDon
Images: 24
Postby MtnDon » Tue Jul 01, 2014 11:56 pm
If I didn't already say so, I must say I am very happy with the Truckfridge. The small freezer was big enough to hold 4 burritos, two meals worth of green beans, a small bag of kale, 2 salmon fillets, a half pound of ground buffalo and a half pound of ground turkey. The fridge held temperature pretty well, with a little air circulation help from a small fan. The fan does really help even out the temperature throughout the box, tempers the rise/fall swings. I did not have the watt meter hooked up to record power use but going by the resting state battery voltage it was miserly in its power use. And it is quiet enough to be hardly noticeable. Not loud enough to be any bother at all. That is with the stock fan too which is more noisy than the one I had picked out as a possible replacement in case the stock fan bothered us.
Some solar will be in the works sometime soon I hope, but there are other priorities at present.
MtnDon
Images: 24
Postby S. Heisley » Wed Jul 02, 2014 1:16 am
Beautiful pictures, Don. Thank you for sharing! :applause:
Glad you are enjoying your new camper. Putting the door in the V front was a good idea. :thumbsup:
Postby lrrowe » Wed Jul 02, 2014 8:21 am
MtnDon,
You and Karen are so fortunate to live in and be able to visit such pretty country. While I like it here in the equally beautiful Appalachians, I envy you very much. Your areas to visit and be in awe of are much greater.
Bob
lrrowe
Images: 439
Postby hankaye » Wed Jul 02, 2014 10:04 am
MtDon. Howdy;
Outstanding pix! Glad to see that all of you planning an scheming,
worked out to a successful outing. Nothing like a nice time that
lasts more than a few days to check for glitches,
Happy to see all worked out well for you and fine tune things.
hank
hankaye
Postby Rainier70 » Wed Jul 02, 2014 10:34 am
Nothing like some days in the high mountains for a great shakedown cruise. Awesome outing! :thumbsup:
Rainier70
Images: 244
Postby MtnDon » Wed Jul 02, 2014 11:04 am
lrrowe wrote:MtnDon,
We love the Appalachians too! We do wish they were closer though. We'd still like to make another trip there. Fall would be nicest in our minds but our part time work schedule does impact that negatively. Late May through the summer would work, but summer heat 'n' humidity makes us take pause on that.
On another note, the brake issue was a broken connection. One of those "wonderful" scotchlok wire connectors failed, or rather the factory installation failed. Now that I replaced it the brakes are fine. My AC electrical problem was a faulty connection. That was my doing. I had pushed a neutral wire too far into the receptacle clamp style side terminal. That resulted in a tiny length of insulation being clamped on as well as the copper wire itself. After some road jiggle or whatever the insulation broke down and that resulted in a loose wire. That could explain why I was getting jumpy readings of around 55 volts with the meter. ??? Anyhow now the 120 VAC works.
Next issue is the little propane leak.
MtnDon
Images: 24
Postby pchast » Wed Jul 02, 2014 10:25 pm
Thanks for the beautiful pictures of your trip.
pchast
Images: 97
Postby dustboy » Thu Jul 03, 2014 4:05 pm
Sweet pics, RMNP is an incredible place. I was there two years ago and the best we could do with our infant son was a "quick" hike out to Cub Lake and a soggy scramble back to the campground as a thunderstorm blasted through. Someday we'll get out there for a more thorough exploration.
What is your BIL's trailer? That thing is a spaceship!
dustboy
Images: 10
Postby MtnDon » Thu Jul 03, 2014 4:47 pm
It is an Element. Called a 26 footer. Aluminum framed, composite sides, roof. His is a single slide 2012 model.
http://www.goevergreenrv.com/page/170/Element
MtnDon
Images: 24
Postby abqlloyd » Mon Dec 22, 2014 3:12 pm
Which Great Stuff foam did you use? I'm thinking of using the door and window, because it's non-expanding. They also have the regular and the big gap brands.
abqlloyd
Postby abqlloyd » Mon Dec 22, 2014 3:13 pm
abqlloyd
Postby MtnDon » Mon Dec 22, 2014 3:39 pm
I used door & window Great Stuff for most places and Dap door & window around the RV door frame. Partly because I had some DAP on hand and partly because the DAP cures to a still soft state. The Great Stuff door & window can still exert enough force to deform things IF it is trapped bewteen surfaces and IF it continues to expand. Which it can. The DAP stuff is approved and preferred by some vinyl window manufacturers, FYI. But I used mostly Great Stuff D&W, but was still careful. But I did end up with one spot in a rear door where some foam got trapped as it cured and it bulged the AL skin a slight amount. (That's what the expansion holes were supposed to prevent.)
MtnDon
Images: 24
Users browsing this forum: Bing [Bot] and 3 guests
