What a job, but all done. I went ahead and rust treated everything I could get to with spray on rust converter and then painted with black Rustoleum paint. The new Timken bearings are really packed well with a quality High Temperature grease. Also, I cleaned up and inspected and tested the electric brakes. It should be good for a while now.
Glad I did the maintenance. The left rear wheel had some play in the bearings and the inner bearing was showing some sign of breakdown. The seal was leaking and grease was black. The original grease in the other 3 wheels still had the red color to it.
Always best to do maintenance at home rather then have to repair on the side of the road. I see that a lot with RV and Boat trailers where they have shredded tires or wheel bearing failure on the side of the highway.
I still have about half the frame to repaint underneath. I sprayed the entire frame underneath with rust converter a few weeks ago. Now I just have to finish spray painting with Rustoleum. Just some minor surface rust, but wanted to stifle it before it got any worse. I think now that the trailer spends most of the time parked on the cement pad instead of the lawn, that helps.
Some nice looking rubber! Hopefully they will last a while.
