Airbags help the ride and the bouncing which should help handling, but really don't change loading.. The Weight Distribution Hitch and airbags together really do the best. They compliment.
Sounds like you've experimented with the combination.flboy wrote:Airbags help the ride and the bouncing which should help handling, but really don't change loading.. The Weight Distribution Hitch and airbags together really do the best. They compliment.
Karebru wrote:Update:
We did our Ft Myers Beach trip a few weeks ago. The little window rattler, AC worked like a champ. It was 90-ish during the day, at a site with very little shade. Our old beagle slept comfortably while we were down the road visiting with family. When we returned in the evening and the sun set, it was a struggle to keep it from freezing us out.
If there's such a thing as thermostat controllers that run cheap window units, I need to learn about them.
flboy wrote:That cord is the thermocouple wire. In my case, the AC and power cord are in an enclosed shroud and closet, so I want a thermocouple I can place in the cabin where I am. They make a model with thermocouple in power outlet if your AC is plugged into Wall in room. In that case, no wire.
This plugs directly into power outlet and device ( air conditioner) plugs into it. Specification says it is good for up to 1500W. 5000Btu AC is much less than that. Around 450W so it should be fine.
I actually have one on the way to test out. I'll let all know if it works. If it does, it is a cheap solution.
Users browsing this forum: DJSpencer51 and 10 guests
