bdosborn wrote:The trouble with this thermal mass approach is the mass keeps diminishing in direct proportion to the outside temperature.
I think I'll call it the izhedrunk enigma. ;)
Engineer Guy wrote:Folks living off grid with +12 or +24 VDC Fridges sometimes use thermal mass to 'coast' the Fridge through power outages, or to reduce Compressor cycling. Some use cases of Beer; some use Concrete Pavers in the bottom of the Fridge; others get even more creative.
My own vision is to put a 'bit' of mass in the bottom of our future CT Fridge or a horizontal 5 day Cooler. This will get us through cloudy days, when boondocking off of PV Panels. It will let us 'charge up' this mass on good Solar days, or from the TV while driving.
Karl wrote:Engineer Guy wrote:Folks living off grid with +12 or +24 VDC Fridges sometimes use thermal mass to 'coast' the Fridge through power outages, or to reduce Compressor cycling. Some use cases of Beer; some use Concrete Pavers in the bottom of the Fridge; others get even more creative.
Let’s see if I understand some of this that you and others have mentioned in this thread.
Adding mass to an electronic cooler helps keep the internal temperature from fluctuating as much as it might otherwise do without mass. Don't think so. The temperature fluctuation will be a function of your thermostat, your system's ability to cool, the temperature of what you put in the box, etc. Adding thermal mass will just lenghten the cycle times. Thus, mass can equate to fewer on and off cycles of the cooler’s compressor although the amount of energy used to maintain the cooler’s temperature over time would be roughly the same as without the mass since mass itself doesn’t have an actual cooling affect, of course. An advantage of using mass is that you are more likely to maintain the needed temperature of your cooler during times that you don’t have sufficient power (from solar or otherwise).
Yes to all of the above.
So, if you were to determine, for example, that you could spare enough space in your electronic compressor cooler for, say, 216 cubic inches of mass, would you use:
A: 1 six-inch cube of mass (surface area of 216 square inches)…or…
B: 8 three-inch cubes of mass laid out apart from each other (surface area of 432 square inches)…or…
C: 216 one-inch cubes of mass laid out apart from each other (surface area of 1,296 square inches)?
You'd like to maximize the amount of surface area to facilitate heat transfer so the answer is "C".
If we were talking about keeping a regular cooler cold using a 216 cubic inches of ice, I assume you would want to you one 6-inch cube of ice if you wanted to maximum the time or yes, if you wanted to cool things down fast, you would use the same volume of ice in smaller pieces, such as 3 inches or even 1 inch, rightyes ? But, for an electronic compressor cooler, do you want to have a fast transfer of heat or a slow transfer? I'd guess you'd want a fast transfer when cooling down the "thermal mass" with the compressor running and the release of the "cold" would be as required to absorb the heat infiltrating into the box which would be slower than the cool down under most circumstances. I'd guess the cycle time compressor on to compressor off (depending on the design of the cooler and the temperature difference between the inside of the cooler and the outside) might be in the neighborhood of one to three. Adding thermal mass will not alter the cycle ratio for a given temperature difference over time but will lenghten the on time and the off time. Should I assume that the answer depend on the interval of time in-between charging the batteries (having solar power)? I'm not sure what the question is.
Two last questions. If expensive were not an issue, what material would you use for mass? Assuming that the answer you just gave was outrageously expensive for most people, what reasonably-priced material would you use for mass? I think that this is your "lucky day". According to the chart here: http://en.wikipedia.org/wiki/Heat_capacity it looks like water is just about as good as/or better than anything as far as having a high specific heat goes!
One other thought: There is a big difference in the energy it takes to heat a gram of water one degree and the amout of energy it takes to melt a gram of ice. If you use a salt water solution blended to freeze right between the on and off temps of your thermostat in your freezer you can take advantage of the "latent heat of fusion" and get a lot longer period of time between cycles as long as you can freeze the salt water fully and thaw it fully (meaning probabaly more and smaller containers of salt water).Sorry for all the questions but I never thought of putting "mass" in a cooler to reduce compressor cycling for times that I might be off the grid without sufficient battery power. Interesting idea to think about.
Thanks!
Karl wrote:I was following reasonable scientific theory (without knowing it) with my non-electric cooler when I had water from melted ice filling up the bottom few inches of the cooler.
kstephenson wrote:After reading the last 3 pages of information. I ve come to the conclusion......I M LOST.....haha
After trying to read all the posts on this subject. I m unable to remember what the point was. I guess what I m trying to say is.....what happen to trying to keep things simple? I believe thats why most of us have gotten into this hobby. Simple Tiny Trailers..... I m sure some of you may have engineering degrees...or maybe think you do......but most of us don't.
Hope I didnt step on any toes here.....if I did,.,,I m sorry....but I had to say something.
kstephenson wrote:I guess what I m trying to say is.....what happen to trying to keep things simple?
kstephenson wrote:I m glad all toes are still present. I guess what I was trying to say was it seem like things were way off the orginal subject......kind of turned into a science lesson.
Happy Camping
