New guy looking for guidance
Re: New guy looking for guidance
Postby Padilen » Sun Dec 09, 2018 1:19 pm
Agfadoc wrote:The bed would be rotated for a side to side in a 7' though and you would have to use twice as much cable to go the same distance, bummer. To raise 4' you have to move 8' of cable in my example.
Maybe use opposing garage door tracks facing outwards with rollers on the outside to keep it positioned and be able to pin at the top with solid base on each side to rest on when you get in at the bottom?... It should work.
I went way overboard with the weight, but 75 lbs for the frame, 50 lbs for the matress plus bedding.. plus buffer? Maybe 150 is more realistic.
Back to the drawing board.
Sent from my SM-N950U using Tapatalk
I think my double is around 100lbs. I made frame light, but memory foam mattress is heavy.
There are garage lifts, there is a capper lift but it's $1100 and only lifts 17.5". I still think the best system was the old Winnebago bunk bed.
My garage door springs work, yet I always think I'd like something else.
Last night I was bored and looked at some "new" CTC you tubes. Wow. Lots of "experts" without a clue. Yet their subscription are high enough they get paid for the videos views. As there's ads and "buy my shirts, become a patron, help support my build".
I'm sticking to this form!
Padilen
Postby Agfadoc » Sun Dec 09, 2018 1:28 pm
Here's an option....
Bed lift - Custom Toy Hauler
https://youtu.be/2oxTPhNPdcU
Agfadoc
Postby Iconfabul8 » Sun Dec 09, 2018 3:47 pm
Iconfabul8
Images: 14
Postby Agfadoc » Sun Dec 09, 2018 5:57 pm
Iconfabul8 wrote:http://www.tnttt.com/viewtopic.php?f=42&t=70758&hilit
Awesome !
Agfadoc
