Here it is I hope.
Default Re: Predator Generators
Magnumtd: As someone who also has many thousands of hours on Chinese generators -I have actually owned, not just speculated about- I must concur with your statements. The last one read 1752 hours on the meter when it suffered a nylon cam failure. No biggie. HF 79.5 cc just happened to be the exact same engine as one used on UST 1350 generator. (Save the FACT that the Predator engine has a steel cam instead of a nylon one.)
With a 20% off coupon I bought a HF engine for $87 SHIPPED to my door. I swapped the tapered shaft crank and side discharge muffler from the old gen onto the HF engine, set speed on govenor and it is running at this moment with about 600 hours on it already without a problem. All I do is change the oil weekly (not a biggie at about 1/2 a quart) and add a strong magnet to drain plug.
I own an old Kohler 4.5 KW and a U.S. military surplus Lombardini 6.5 KW gen that I use for my high power needs, but running on generator as my primary source of power I am much more interested in fuel efficiency and running time per tank. I get between 12-14 hours of gen power from a 1.1 gallon tank.
I've had FAR more problems in far fewer hours on both my Kohler and my surplus gen. A new automatic choke for my Kohler is priced at $234! The wiring on my USA MADE surplus gen (with Baldor gen head) was absolute CRAP that melted into a blob on the connector between gen head and output panel. (US mfg used CRAP 9A MOLEX connectors on 20 A circuits. My springtime project will be to fully rewire output using 40 A barrier strips between gen head and output panel.)
I wonder just how many hours actual running time -without any failures- all these China bashers are getting on their beloved Onans and Kohlers. I KNOW I can count on getting well over 1000 hours of REAL DAILY USAGE out of my cheap Chinese crap. And then buy TWO replacement engines for less than one Kohler replacement part.
I guess everyone is entitled to their own delusions.... I just choose to base mine upon actual experience instead of heavily biased speculation.
Let the flames begin!
Doc
