Its sort of mine!
Re: Its sort of mine!
Postby facethewolf » Wed Apr 05, 2017 2:32 pm
What's with cables (hoses?) Wrapped around the trees?
Sent from my SM-T230NU using Tapatalk
facethewolf
Postby flboy » Wed Apr 05, 2017 2:36 pm
Enjoy the first trip of the season!
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Padilen » Wed Apr 05, 2017 3:24 pm
facethewolf wrote:What's with cables (hoses?) Wrapped around the trees?
Maple trees -(sugar bush), tapped to make maple syrup. I work helping @The Highland Company to produce and bottle Awesome Woods Maple syrup.
Padilen
Postby Padilen » Fri Apr 07, 2017 7:07 pm
I saw a cooler in our dumpsters the other day, so I dived in! Looks like a hunter hauled the meat of a deer in it. It's a wheele Coleman the wheels were inside withe the axle. I cleaned it up today and need to get the retainer for the axle/wheel. The blood/ raw meat smell is still noticeble so I left it in the sunshine. Hoping it's going to be usable.
Padilen
Postby hankaye » Sat Apr 08, 2017 10:09 am
Padilen, Howdy;
Throw a handful of coffee grounds (un-used), in it and leave the lid open. Should have the smell out of it in a few days.
hank
p.s. Had a 48' trailer that had hauled renderings from a slaughterhouse to a dog food factory once that had
set in the sun for a week. Well it took a full can of coffee and another week but you could get in it again, and
that was a wood floor and walls. Plastic deodorizes faster.
hankaye
Postby McDave » Sat Apr 08, 2017 4:51 pm
Soap and water, bleach, rinse. Sunlight then charcoal.
Mostly keep open to the sun.
McDave
McDave
Images: 412
Postby working on it » Sat Apr 08, 2017 5:36 pm
Padilen wrote:I saw a cooler in our dumpsters the other day, so I dived in! Looks like a hunter hauled the meat of a deer in it....
I hope you're right, but around some areas, I wouldn't make that assumption... :o
173193172890148599
working on it
Images: 457
Postby Padilen » Mon Apr 10, 2017 5:57 pm
The hair on it was the clue, to deer. A neighbor's a butcher and during hunting season he works at home. Since we have community dumpsters I've seen this kind of stuff before, and much more!
Padilen
Postby Padilen » Mon Apr 10, 2017 6:02 pm
Once again my camping plans ended after one night. I forgot my meds and on top of that my allergies kicked in. The accumulator tank didn't help, my hot water issue! I'm trying different settings on heater and pressure for accumulator. The only other thing I could think of is if it's directional - but the package says mount any position.
Padilen
Postby Padilen » Mon Apr 17, 2017 8:11 pm
Friday I hauled my CTC over to the sugar bush. Never unhooked or unloaded cycle! Just came home as storms were forecasted. Rained during the night, no thunder storms. And of course Saturday was beautiful. Rain Easter Sunday morning then another beautiful day. Today was cold and it managed to sprinkle again. It's spring it's Michigan :shock:
Padilen
Postby hankaye » Tue Apr 18, 2017 8:13 am
Padilen, Howdy;
What was the problem with the hot water again? Went searching and didn't stumble on it.
hank
hankaye
Postby Padilen » Tue Apr 18, 2017 8:31 am
It's mentioned in Tommys build. I've only noticed it when using water pump. But the water either is to hot or to cold. Only briefly at the set temp. I believe it was Don that suggested to Tommy the accumulator tank.this is the one I bought. SEAFLO Pre-Pressurized Accumulator Tank https://www.amazon.com/dp/B01MVA6GCC/re ... 17jbNRzkrR
SEAFLO Pre-Pressurized Accumulator Tank https://www.amazon.com/dp/B01MVA6GCC/re ... 17jbNRzkrR I bumped up the pressure from 10 to 25. Didn't correct the issue, I'm now up to 35 but untested.
Padilen
Postby hankaye » Tue Apr 18, 2017 9:01 am
Padilen, Howdy;
What kind of hot water heater do ya have? RV type or "Instant"? If yo have a regular RV type how do ya have
the shut-off valves set-up? Just 1 for the cold inlet and a check-valve in the hot output? OR ... plumbing
looks like a sideways H with bottom being cold upper being Hot and vertical being the connector for when
winterized. In older RV's there were 3 shut-off valves, 1st. between vert. line and cold inlet, 2ed. between
hot outlet and vert. and 3rd. in the vert. itself (what I had in my former RV). My water temps stayed where
they were set. (hot and cold valves open and vertical closed)
http://s1352.photobucket.com/user/bflin ... e.jpg.html
In this 'newer' RV I have a double shut-off valve set-up with the check-valve in the hot outlet eliminating the
hot water shut-off valve, So, I point the shower head away from me when I reopen the sprayer give it a 3 count
and the hot has remixed with the cold.
Hope this helps some.
hank
hankaye
Postby Padilen » Tue Apr 18, 2017 9:27 am
I'm sorryi should have said, I have the outdoor instant hot water heater. But not being able to use the app makes it difficult to post. I can't see what I've typed other than a few words.
Padilen
Postby hankaye » Tue Apr 18, 2017 11:40 am
Padilen, Howdy;
Not a problem ... I've zero experience with the type you have so I have
no thought as to why you have your problem other then to surmise that
the mixing valve isn't doing it's job propeerly
:thinking:
hank
hankaye
Users browsing this forum: Google [Bot] and 5 guests
