EvenOlder wrote:I would surely appreciate any pics and/or notes about your mini-split AC system.
I'm looking to do the same (Sarasota FL camping!) in a 7x16
Thanks-
OverTheTopCargoTrailer wrote:SEER 15 my friend and it does appear to come with 15' copper lines.
The op said his unit was SEER 20.5 so it's a slightly different model, but however still a very good deal.
One BIG DIFFERANCE, between this unit and more expensive units like Fujitsu at $2079.00
https://www.acwholesalers.com/Fujitsu-Air-Conditioners/9RLFFH-9000-BTU-26-SEER-Ductless-Heat-Pump-System/52507.ac?gclid=CjwKEAiAkvmzBRDQpozmt-uluCQSJACvCd1lrAsAGvwi0CMJM8ozuDfXgiZYefhoXcmSxvi1W5xXShoChP_w_wcB
There is also now a SEER 33 model WOW at $1795.20
https://www.acwholesalers.com/Fujitsu-Air-Conditioners/9RLS3-9000-BTU-33-SEER-Ductless-Mini-Split-Heat-Pump/52509.ac?catId=cat1028&mainCat=&subCat=&trail=68442:33.00
is that it only gives you 5500 btu heating at 17F vs expensive unit gives you 10,000 Btu at 5F. The same applies to the cooling at up to 123F - for example most all roof top or home or window ac units no longer cool over 105F.
They run, but they no longer cool & that's when they blow up or break down as one might say on the hottest day of the year. With ac units you always get what you pay for - there is no free lunch.
Cheers OTTCT
