tsyj, Howdy;
As for the Portable A/Cs they get mixed reviews here. Some swear by them others swear at them ...
Try the Google custome search box top center (sorta), and you'll be able to see what others have
had to say.
hank
tsyj wrote:
Thanks! It is St Andrews SP in Panama City Beach. It was a perfect site, backed up to the dunes. Yes I am definitely going to add AC. Was going to add a 5k BTU window unit to the drivers side, but after visiting with another cargo camper at the park, I am looking into a portable unit and 3" vent hose instead....any input?
hankaye wrote:tsyj, Howdy;
had to say.
hank
flboy wrote:
I have used both and the window unit will do a better job and do it more efficiently. The portable draws warm moist air in from outside the CTC to run across the condenser coil unless it is a 2 hose system. Also, you may a hard time finding a portable that is small enough to run off a 2000W generator whereas the 5000 BTU window units will cost less and you can run it with a small generator. Just some stuff to think about.
Either way you go.. your trailer is small enough where anything you put in is probably going to be overkill for the volume of air it has to cool.
Hader wrote:tsyj,
"but when you press down on the front edge of the top, it actually lifts up at the back and out of the cleat."
Would this help? http://shop4seats.com/rv-furniture/dine ... pport.html
Truly like the French cleats for the storage unit. Leads me to a new question, are you going to rely
on the weight of the items stored to hold it down or are you going to have 1 screw through a cleate
to prevent it from doing a back of the school bus bounce?
hank
McDave wrote:Boy, that looks like some very effective storage solutions. Handy, accessible, durable...very nice.. The colors and panelling scheme should lighten and brighten an otherwise small dark space. I like the headliner idea, this is what I am using with batten strips screwed into the roof supports. The size and price are right and it is very tuff stuff.
http://www.homedepot.com/p/Foss-Hobnail ... /202042703
I used the Taupe for the headliner and the Granite for wall covering.
http://www.homedepot.com/p/Foss-Hobnail ... /202042701
McDave
McDave wrote:Shabby-chic, I like it. We used to "distress" using chains, bolts and wrenches or other hard items thrown or slapped against the fresh wood and round off sharp corners and edges randomly. Then some stain to darken the wounds, then light sanding and re-stain entire piece. You could add years of "patina" in minutes.
Is that a sofa table?
McDave
