Re: Its sort of mine!
Posted: Sun Jun 11, 2017 11:25 am
Well, that didn't take long. Just as predicted. ... ..
So, heat has a cumulative effect when it comes to refrigeration. Sure you could remove the heat from the condenser with 100, 110, 120f air. and since it is in a small well insulated space that's just what happens. And since the air used to cool condenser is ever rising in temp, the reefer will be exposed to hotter ambient temp, causing it to cycle more often and run longer cycles adding more heat to the air used to cool the condenser, making it even less efficient, causing it to run longer etc,.etc., ad nauseum.
Also, as we both know, if you need the heat from the refrigerator in the winter, you have bigger problems. It's more likely you will have to heat the refrigerator to keep it from freezing.
But hey, since you will likely have to a hole or two in your trailer either way, multi tasking might be too complicated given the proximity of the two appliances, it's got to be literally...centimetres if not inches.
Ever wonder how it is possible to be hotter in that well insulated trailer than the outside temp? VooDoo maybe? Or not.
McDave
McDave
