Well, aside from connecting up a few outlets, tucking away wires, bundling them neatly with tie wraps, and mounting the indicator panel shown in the pics below, my electrical system is up and working.
I am running off solar now. I tested the inverter under full load. It runs the Fridge and Microwave with room to spare. The pics below show the Kill-A-Watt meter on the front of the inverter that monitors to AC output, and the bottom one is a panel I got of Amazon for $15.00. I had to connect a current shunt in the return line from the inverter, but basically it monitors current, voltage and power usage for the inverter. It will be handy when boondocking as you have to manage total power usage so as not to overload the inverter or run the batteries down below 10.5V. When the meter indicates 100A.. it's time to shut something down. I can also see any difference between the voltage at the batteries and the voltage at the inverter. You can see in the pics they differ by about .1 volts.
I am going to mount this right above the Solar Charger/Controller so at a glance, I will be able to monitor the input to and output from the batteries .
