Gil,
Nice work! And thanks for the update.
Rubber grommet or caulking in holes where wires pass through metal?
Prem
Prem wrote:Gil,
Prem
Prem wrote:Gil,
Why fiberglass for those rounded, upper corners? If it gets compressed, it loses R value. It rains tiny glass fibers unless one caulks all the panelling seams air tight (NG either way). Open pockets of no insulation develop as the fiberglass batt gives way to gravity after just a little traveling/pounding down the road.
Expanding polyurethane spray foam in a can! Wires don't move either, but they're buried. No problem. You used good wire and have appropriate fuses on every 12 VDC line going to reading lights, etc., right?
With the foam sanded flat, your idea about glued on fabric is easy and interesting. In the alternative, you could cut a run of plywood to go in on a 45 degree angle to cover the foam (without sanding). This run (say 10 inches wide), gets angle ripped sticks glued to it that perfectly mate to the ceiling and wall panelling. Predrill it and voila! Rounded corners made flat, perfectly insulated and covered.
Prem
I'm of using 3/8 inch plywood and using long sheet metal screws into the top bows to wedge the plywood against the ceiling and wall. Kind of like a cove strip is installed in a home.
Prem wrote:Gil,
[b]Where in Oregon?
Prem
Prem wrote:[
... Real men don't use blade guards.
Prem
Prem wrote:Gil,
Prem (with multiple push sticks for the table saw)
Users browsing this forum: No registered users and 23 guests
