6 X 10 (V-nose) build
Re: 6 X 10 (V-nose) build
Postby Modstock » Sat Mar 21, 2020 9:27 pm
Im just about where you are on the build.
Picked up some 1/8" white hardboard and some lattace for the seams.
Would have went with some luan but didn't want to paint.
The white ceiling should break up all the grey.
Also picked up some teal paint for the cabinets.
Always wanted to do that color on the teardrop but didn't happen.
Sent from my H1611 using Tapatalk
Modstock
Postby flboy » Sun Mar 22, 2020 7:55 am
Hi. I used Luan plywood for my celing. Number 1 tip, paint it or put whatever finish on it before you install and only touch up after. I hate painting over my head.
Also, 1×2 furring strips into ceiling joists 16 inches on center will allow for double insulation and then you can screw luan into the furring strips.
Keep in mind that whatever you put in for cabinetry or walls, also acts as ceiling support assuming it butts up to the ceiling.... so you do not have to go overboard on screws. Just make sure it is snug so no sagging.
Just one way to do it.. but double insulation in ceiling is good and relatively cheap to do at this stage.
This is what mine looked like just befor I put second layer of insulation in between furring strips.
And after.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Modstock » Sun Mar 22, 2020 9:42 pm
Here's my weekends progress.
Yesterday
Barrowed the glue pot from work and carpeted the walls.
Mounted the front wall cabinet with extra bracing behind.
Today started on the ceiling.
Since the V-nose dives down , there needed to be something somewhat flexible.
Had some plastic shower board I had laying around and tucked that under the hardboard. Pic 2
Still need to put up some corner trim to help hold up the sides and
flat trim where the seams are.
Modstock
Postby BigDave_185 » Sun Mar 22, 2020 9:50 pm
Looks good, I will be putting some 3/4x 2 inch alder on my ceiling/crown molding area. With the size of your trailer in thought I might actually have some painted white poplar at the shop we could work a thing out for maybe
BigDave_185
Postby Modstock » Sun Mar 22, 2020 10:19 pm
Sorry I didn't PM ya sooner. Was out cleaning up tools and materials.
I guess we had another quake around 7ish.
Was in the trailer and didn't feel it. (thought it was the normal trailer moving around while I work inside ) but I heard the house settle.
Google said it was a 4.0 out of magna .
Modstock
Postby Modstock » Wed Mar 25, 2020 7:30 pm
Ceiling done.
And started painting the doors. Another item I had laying around.
Matches up with the carpet.
Here's where the fun stars. Building the bed, cabinets, sink, etc. Stay tuned.
Modstock
Postby McDave » Wed Mar 25, 2020 11:16 pm
Oh yeah. Very tidy. Nice work Modstock.
McDave
McDave
Images: 412
Postby Modstock » Fri Mar 27, 2020 5:38 pm
Thanks.
I may change out that corner trim . There's a few gaps I don't like.
Right now im building the frame for the bed and the decision to go full or queen will be made here soon.
Modstock
Postby Modstock » Sun Mar 29, 2020 12:34 am
Found some 1-5/8" trim that I liked. Plus I can get the brad nails lower, to avoid the wire's.
Started the bed frame.
Modstock
Postby Modstock » Sun Mar 29, 2020 2:24 pm
Bed frame is in. Have room for a pretty big slide out drawer . Decided to lay down the spare, should be quick and easy to get to.
Was able to get the bed frame up into the V-nose an 1-1/2". That's why I built the front like that. To chop one side down a bit.
Also gained an inch at the rear.
Tried to order/pick up the mattress but IKEA is fully shut down.ImageImage
Modstock
Postby Modstock » Mon Mar 30, 2020 9:10 pm
Dosent look like much. Last mock up.
Used some 2x4's to set on for proper height.
Knocked the back wall of the cabinet out. Moved it out to 17" to make it easier to pull the tanks out. Plus room for expansion when filled.
Some bathroom wall art/humor (last pic).
Modstock
Postby Modstock » Sat Apr 04, 2020 10:18 pm
Was supposed to work on the trailer today but ended up sewing up masks for family.
Elastic is getting hard to find, so I used stretchy hair ties.
Modstock
Postby onehoser » Sun Apr 05, 2020 5:21 am
couldn't help but post this. please delete if improper post
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby flboy » Sun Apr 05, 2020 2:21 pm
:lol: :lol: :lol: :lol:
I can relate. I am more of an introvert, so the isolation isn't bothering me much. My wife is more of an extrovert... so much harder for her.
Don (Flboy)
flboy
Images: 378
Postby Modstock » Sun Apr 05, 2020 3:17 pm
Me too. This isolation thing ain't that bad, if your building a trailer.
Wrapping up the bed frame and such.
Put the hinges on the rear of the bed for storage. The slide out drawer will be 20"w X 24" length and 10" deep.
Also more storage to the left.
Storage, storage, storage...........
Trying to lighten where I can, so recycled trim is slats for the rest of the beds non important sections.
Bed is done.
Sent from my H1611 using TapatalkImage
Modstock
