Iconfabul8 wrote:How has the side mounted fantastic fan been working for you? Anything you would do different?
Hader wrote:Alex,
Would you happen to have any photos or sketches of your Grey water setup?
My build will have the Shower in the front, I won't be able to use a tank. Was thinking about 4" or 6" pipe.
flboy wrote:Alex,
I Really like your loft bed and need to build one myself. Do you have any details you could share? How are the struts working and how far down does the bed travel?
I had a design in mind, but yours looks to be more simple and I like that.
Sent from my SM-N900P using Tapatalk
wanabxtrm wrote:flboy wrote:Alex,
Sure thing I'll try to grab some more pics for you and give you a better synopsis. Theres some earlier in my build too if you didn't already look. There's also a few bed discussions on here that highlight it, as well as similar designs that inspired me. I don't post much so you could look at my old posts to find the threads if needed.
Short story is 5 uni-struts per side three horizontally to the trailer frame and 2 vertically which attach to the horizontal ones. The vertical ones hold the weight of the bed and occupants on movable brackets. The bed is a ladder style frame with plywood on it the same width as the distance across between the opposing vertical supports. If you don't move it often that's all you need. You could physically affix the bed to the brackets and call it a day. Since we move it 2x or more a day we put in the gas struts (and its overbuilt and heavy to lift on its own).
Re: struts:
Basically find the 'top' of the bed travel when up this is your top reference point, place your strut here at a 45 degree slope (or as desired) down. This is your bottom reference point and should be where a horizontal brace should be. Connect them at each corner of the bed.
wanabxtrm wrote:
