hankaye wrote:nunrleft, Howdy;
Try one of these. Shop around PPL is a good place.
http://www.adventurerv.net/dometic-ther ... ce=Froogle
hank
Stinger381 wrote:Awesome build. I am about to try about the same thing with my 7x16 cargo trailer. My biggest concern is that mine doesn't have windows. I want to order some and install but I don't want lo cut the rib supports. Was wondering if you had some more pics of how they installed the windows. It looks like the factory screwed the windows in the skin and then you have a trim ring that covered the Luan and secured the window to the interior paneling? Is that correct? Love the led lighting and will definitely have to try that. Looks great. I will be putting propane bottles on the tongue and using them to cook from. I already have the same ac unit that you have but will not run heat from it.
Stinger381 wrote:So are the windows screwed from the outside or do they simply wedge between the skin and plywood with the trim ring?
Thanks for the pic.
rebapuck wrote:Flawlessly doesn't mean perfect does it? Anything you would change now that you've camped in it?
rebapuck wrote:It looks great. How many tours did you give?
