Padilen wrote:That seems a little low, for such a lite trailer. How many miles on the TV? Plugs ?
Either way I'm sure you'll have fun and see lots if interesting places and things.
McDave wrote:Hey Kathy,
That looks pretty good! The sun sail/shade cloth looks like it should work well.
For some reason I thought you were headed to Wisconsin. But hey, Georgia is nice, too.
Have fun and be safe.
McDave
flboy wrote:Looks like you had a great time. Sorry to hear about the troubles with the jackstands in the back. How do you deploy them?
In case you didn't know ( I was shown the correct way), typically, you want to lower the nose down as low as you need to deploy the stabilizers on the rear to whatever point they hit the ground, then crank up the nose until level from front to back. Side to side should be level if the trailer tires are essential not loaded by the trailer weight. Essentially you have a three point mount... You could then crank up just barely past level and then put those new portable stabilizers under the two from corners and bring back down to take the weight off the tongue... then you have a 4 point mount that should be level and very stable.
Take care.
