Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Re: Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Postby flboy » Mon Mar 22, 2021 12:20 pm
ISOTNT wrote:Are those fridge shelves tempered glass or acrylic? I was thinking of returning the 4.2cu ft MAgic Chef one I got as the shelves are glass and I am afraid to really use them while traveling. I was thinking of replacing them or maybe just returning it for one without the glass. Also, if you don't mind me asking, what are you intending to use to keep the fridge door closed in transit? Thanks!!
I believe the shelves are glass. The 4.3 CuFt Magic Chef I have in my existing CTC is the same. Never been an issue for travel. I use a baby lock to keep the door closed during travel.. below is an example. There are other similar types that will do the job also.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Mon Mar 22, 2021 12:26 pm
bdosborn wrote:Can you meter the kwh usage for a 24 hour period with the kill-a-watt? That will tell you a lot more about the energy usage than just the watt draw.
Hi Bruce. I can for sure and am in the process. I will update tomorrow on 24 hours... may be a little high since it has to pull some water and etc.. down... will do again for 48 hours and assume the second 24 hours will be more typical..
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Mon Mar 22, 2021 1:37 pm
Perfect!
Thanks,
Images: 777
Postby ISOTNT » Tue Mar 23, 2021 7:46 am
Ahh, very cool. Thank you! I was just trying to decide how I wanted to connect magnets like I am using on cabinet doors/drawers, but I like the baby lock idea better as if something falls from the fridge in travel, I could be surprised by a big mess once I get to camp.
ISOTNT
Images: 6
Postby hankaye » Tue Mar 23, 2021 7:58 am
ISOTNT, Howdy;
Have you contacted the manufacturer to see what the type of glass is? That would have been my
first call/email. Get the info. straight from the horse's mouth so to speak. Then there is NO doubt.
hank
hankaye
Postby flboy » Tue Mar 23, 2021 8:01 am
Well, my trailer is delayed according to manufacturer. The 5,200 lb straight axle is backordered. They are not expecting it until April 2 now and said it would be mid to late April for finish. Guess I will go camping until then.. Taking the 7*18 out for 4 days next week.
Have al the stuff to build except the most important piece! LOL
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Tue Mar 23, 2021 8:22 am
Just bring all that stuff up here and I’ll show ya how to weld like a champ and we can hit the single track all morning
BigDave_185
Postby flboy » Tue Mar 23, 2021 8:39 am
BigDave_185 wrote:Just bring all that stuff up here and I’ll show ya how to weld like a champ and we can hit the single track all morning
Thanks... going to try welding today. Setting up the garage now. Going to try to fabricate some tilting solar panel racks for the roof. It might be ugly... LOL :cry:
Don (Flboy)
flboy
Images: 378
Postby flboy » Tue Mar 23, 2021 8:43 am
Okay... Fridge ran 24 hrs. and took .510 KWK or 510W hours @ 110VAC. Basically that breaks down to 40.8aH for 24 hrs at 12.5 VDC.. I think that is high, but the fridge only had 4 bottles of water in it and a small ice cube tray, so no real thermal mass. I am going to load it up like I was going camping... let it all come down to temp, and then measure a 24 hour period with the door being opened up randomly a few times. Will report back Wednesday PM for anyone interested. That would be a more realistic use case.
Okay.. loaded up. Once this get down to temperature, I'll reset clock and Killawatt meter and check after 24 hours.
Don (Flboy)
flboy
Images: 378
Postby onehoser » Tue Mar 23, 2021 9:29 am
hmmm, something’s not quite right........i don’t see beer...
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby BigDave_185 » Tue Mar 23, 2021 9:33 am
What welder set did you pick up?
BigDave_185
Postby foxontherun » Tue Mar 23, 2021 10:54 am
Good morning Don,
Wouldn't a more realistic test be to put fridge in your garage or other trailer since your house is "conditioned" space? (Making the assumption your picture is from inside your house :) )
Harry
foxontherun
Images: 71
Postby bdosborn » Tue Mar 23, 2021 12:22 pm
You're at 1.6 amp-hr @13.2V (Lithium voltage), which is a little higher than I would have expected based on my kegerator tests. Is your fridge Energy Star rated? But then again, the kegerator had some thermal mass in it :beer:. I suspect my meter might be a little off too as it's a chinaclone and not a real Kill-A-Watt. Good info, thanks for posting it!
Images: 777
Postby bdosborn » Tue Mar 23, 2021 12:37 pm
P.S. Just checked and I think it is Energy Star rated.....
Images: 777
Postby flboy » Tue Mar 23, 2021 2:34 pm
BigDave... sad to say what it is. I got it for nothing about 5 years ago and never used it. It is a Chicago Electric 90A Flux Wire Welder from Harbor Freight that runs from 110VAC. I am using .030 flux core mild steel wire in it. Not good for too much I suppose , but I will learn to run a good joint and then move up. Reportedly it will weld 18 gauge (0.048") to 3/16 (0.19") mild steel... which should be enough for the steel tubing (1/8" I believe) on the CTC Framing. Going to use it to frame the windows and a few minor things. If I need more than that , I have access to use professional type welding equipment at my brother's shop. I wish I had a bandsaw too... would make some cutting much easier!
This is ugly and I am not proud of it, but never welded before today. Built a roof mount that will bolt onto side trim into roof frame. Had to notch out for the drip edge to fit so it would mount flush.
Need to make three more that will bolt on side and then I am going to use aluminum angle stock to bolt on for mounting solar panels. Still working out how I am going to tilt. Toying with some ideas using electric linear actuators so I can tilt panels up with the push of a button.
Don (Flboy)
flboy
Images: 378
