catrinka wrote:Mike, take a look at my pics and you will see what I did with my galley. I, too camped with the trailer before putting in the galley wall. It worked okay but it is drafty (especially in Sept) for sleeping.
prohandyman wrote:Mike
I installed a rv latch on my cargo, with just a little difficulty. My door thickness is shy by about 1/4", but I can build that up with a wall panel. The framing around the door was a liitle tough to cut into for the latch to strike thru. And I plan to remove the cam bar altogether and fill the holes. I also would like to put rv latches in the rear door.
I only wish it were 10 ft long, as the cabin will be snug. Good thing the wifey and I still like each other. I am trying to calculate weight so I know if I need to move the axle or not. It seems a little forward. This pic still has the cam bar attached.
prohandyman wrote:26" from side to side of trim. Window is 13" wide. Had to trim some of the strap hinge back on the top one.
Trackstriper wrote:Mike-
Glad to hear you got a trailer ordered. Having a shell to start with will knock a lot of time off your build.
I like the idea of a bright, cheerful color...it will add a lot of fun to the project. So is this trailer school bus yellow? Or is this going to be a lemondrop?
Best wishes
After using the trailer balance spreadsheet, I have decided to move my axle back 7 inches on my conversion, to accomodate to galley weight in the back. And since my trailer has a torsion axle, I just bought 2 mounting brackets from a trailer dealer, planned on welding them to the frame. But, the old brackets are welded on solid (which is re-assuring) so I had to modify my new brackets a little to fit. Just tacking them in the spots I want, since I just have a 110 vt wire feed welder. Will take it to a welder that has more capacity for a better weld. I will show you pics when I get it welded. I had hoped to leave the axle where it was, but just too much weight out back.
MikeDrz wrote:I Plan to Gerdo.... but 6 - 8 weeks for delivery!Gerdo wrote:Pictures when you get it!
