Tongue jack problems
Postby prohandyman » Mon Mar 12, 2007 7:00 pm
Had to be a little creative (when aren't you when building a teardrop) with the tongue jack. After replacing the swing-up jack with a verticle one, and installing a tongue box, clearance for the jack handle became a problem. It would not clear the box to turn. So I removed the handle, replaced it with a 1/2" - 3/4" pipe reducer, and made an adapter for my battery drill
(poor man's electric jack) to raise and lower the jack. Works great!Image
Dan
prohandyman
Images: 785
Postby toypusher » Mon Mar 12, 2007 7:08 pm
I have the same problem with handle clearance. That's a real nifty solution there and I may just try it myself. Probably won't carry the cordless drill, but will use a ratchet that I already carry or my trusty 4-way lug wrench! 8)
toypusher
Images: 324
Postby MikeDrz » Mon Mar 12, 2007 7:28 pm
Carry the drill! you can use it in the gallery with a blender blade. :)
toypusher wrote:I have the same problem with handle clearance. That's a real nifty solution there and I may just try it myself. Probably won't carry the cordless drill, but will use a ratchet that I already carry or my trusty 4-way lug wrench! 8)
Michael Drzewiecki
Teardrop Dreamer - Cargo Converter
Click here to check out Cargo Conversions...its hip to be Square!!!
MikeDrz
Postby mwatters » Tue Mar 13, 2007 10:35 am
A sidewind jack would solve that problem as well... That's what I got for my little cargo trailer when I wanted to mount a box on the front.
Mike
Mike
Watters
mwatters
Postby Leon » Tue Mar 13, 2007 11:45 am
Or you could go electric like I did
Leon
Images: 21
Postby prohandyman » Fri Mar 16, 2007 8:15 pm
Both good ideas, but I already had this jack and I'm a cheap-scate. Actually I had a swing-up jack on it before this one, and had to remove it for the tongue box clearance.Where was my head? :thinking:
Dan
prohandyman
Images: 785
