My Project a Cargo Trailer for back country camping
Re: lift ?
Postby meach4x4 » Sat May 15, 2010 1:20 am
Crazylegs wrote:I am a Jeeper and want to know how you did the 4" lift. Great job by the way. Did i see a Utah plat. I am in Salem and you?
I did the lift the recommended way from Wells Cargo. The stock axle is a torsion spring axle. Wells Cargo sent me two 18" long pieces of 2"x4" steel tube and had them welded between the frame and the axle mounts. After looking at it with the wheels off, I realized a better approach would have been to swap the axle. The stock axle is 22 1/2 degrees negative. I could have swapped it for a 22 1/2 degrees positive axle with brakes for not that much more than the riser tube method. If I was doing it again, I would have done it that way, and ordered a lighter spring rate, also.
It is a Utah plate. I am in St. George. Howdy, neighbor!
Gil
meach4x4
Images: 126
Postby meach4x4 » Mon Jun 21, 2010 9:27 am
I'll have some pics and updates on the site here "Coming Soon!"
meach4x4
Images: 126
Postby Crazylegs » Mon Jun 21, 2010 4:43 pm
I think your set up had some influence on me :D
Image[/img]
Crazylegs
Images: 72
Postby meach4x4 » Mon Jun 21, 2010 11:36 pm
Crazylegs wrote:I think your set up had some influence on me :D
[/img]
:applause:
Yes, I see some evidence of influence there. Nice looking setup! How is the inside?
I lived in Aumsville for 8 years. Loved it there. Now, I'm down south in St. George, Utah. I will be headed north for vacation in a few weeks, though.
Gil
meach4x4
Images: 126
Postby Crazylegs » Tue Jun 22, 2010 1:31 am
Check out my albums there are some pics there. Itit just ruffed it to check out the setup now I am making some changes and putting back together.
Crazylegs
Images: 72
Postby alefl75 » Sat Jan 29, 2011 4:15 pm
What type of 4" lift spacer kit did you install?
alefl75
Postby Prem » Sat Jan 29, 2011 7:08 pm
:thumbsup: Beautiful job Crazylegs! :thumbsup:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Jo » Tue Feb 01, 2011 10:59 am
alefl75 wrote:What type of 4" lift spacer kit did you install?
He said previously:
Jo
Postby alefl75 » Mon Feb 07, 2011 10:40 am
How would you be able to lower the axle??????????
alefl75
Nice write up!
Postby Taco Jeff » Thu Jul 28, 2011 9:04 pm
Gil, after seeing your write up in Four Wheeler magazine,(congrats) I have decided to go to a 5X10 vs a 6X10. 5X8 is too small for what I have in mind. My question for you is about the V nose. Have you ever touched the top of the trailer to the back of the Jeep when you go through a deep dip while off roading? I think we four wheel around the same areas.
Thanks.
Jeff
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!"
— Hunter S. Thompson
2000 Landcruiser 100 series, 5X10 Haulmark Cargo Conversion, Heart attack survivor 2/22/2010
Taco Jeff
Conflicts
Postby Engineer Guy » Thu Jul 28, 2011 10:24 pm
Re: the pic above... Any Spare Tire -> CT Tongue Jack Handle interference?
Engineer Guy
Images: 118
Postby Prem » Sat Jul 30, 2011 1:21 am
Not my sandwich on portapotty.
:rofl2:
My goal...
Prem
Images: 144
Back Country Camping
Postby SteveB » Tue Aug 02, 2011 1:58 pm
I too plan to use my 5x8 for back country camping. I will use it as a base camp since my suspension is not good enough for anything other than fairly smooth dirt roads.
http://tnttt.com/viewto ... ght=steveb
SteveB
Re: Nice write up!
Postby meach4x4 » Thu Aug 18, 2011 12:03 am
Taco Jeff wrote:Gil, after seeing your write up in Four Wheeler magazine,(congrats) I have decided to go to a 5X10 vs a 6X10. 5X8 is too small for what I have in mind. My question for you is about the V nose. Have you ever touched the top of the trailer to the back of the Jeep when you go through a deep dip while off roading? I think we four wheel around the same areas.
Thanks.
Jeff
Thanks Jeff
Actually, it is in the September Issue of 4 Wheel Drive (not Four Wheeler) Magazine.
I've never had a problem with the top of the trailer hitting the back of the Jeep. The fixed trailer nose jack is the closest thing to the spare on the back of the Jeep and it hasn't hit. I was planning on putting on a flip-up if it ever hit the spare, but not a problem yet.
By the way... This trailer is FOR SALE!!! I bought a pop-up camper and a boat. No more room to store the trailer, so it (sniff, sniff) needs to go to a good home. :cry:
meach4x4
Images: 126
Postby iSpy » Thu Aug 18, 2011 3:24 am
Just come across your thread ........ good trailer.
I would add one comment, why do most narrow CT have the bed 'front-back' ....... they can be made to fit 'side-side' ....... if you stretch the side.
The side door would have made a good 'slide-out' panel.
See my link below. This makes much better use of the barn doors. (I think)
http://tnttt.com/viewtopic.php?t=44263
Mine is made from a 8x4. when both slide-out are open the CT is wider than it is long.
Here are some links to the initial build....
http://tnttt.com/viewtopic.php?t=44261
http://tnttt.com/viewtopic.php?t=44262
I hope this helps some others.
iSpy
