mx842 wrote:I'm asking this because from what I have seen written in many different sites that the 3 stage chargers will never get the batteries to a full charge because they take power from the batteries in order for them to work. I have seen this on boats before with shore power/charge systems and have installed an on board stand alone charger in addition to the one in the unit with no problems. I was just wondering is these RV type chargers are different. Mine got fried and the guy I bought it from said that was the reason it burned up and why there would be no warranty.
fromeo wrote:If you feel the need to run an outboard charger then I would disconnect the WFCO when running the outboard.
- Frank
eamarquardt wrote:mx842 wrote:I'm asking this because from what I have seen written in many different sites that the 3 stage chargers will never get the batteries to a full charge because they take power from the batteries in order for them to work. I have seen this on boats before with shore power/charge systems and have installed an on board stand alone charger in addition to the one in the unit with no problems. I was just wondering is these RV type chargers are different. Mine got fried and the guy I bought it from said that was the reason it burned up and why there would be no warranty.
Not sure where you're getting the above information but it sounded kinda wierd based upon what I read and my expernece.
So, I called WFCO (and spoke to John at (574) 294-8997). He was very nice, knowlegeable and explained the following:
When there is a load on the battery or the battery voltage is low and the WFCO unit is powered up it will provide 14.4 volts. This is called the "bulk mode". When the load on the WFCO unit drops to about 5 amps at 14.4 vollts for about 4 hours the unit will drop down to 13.6 volts and stay there. This is called the "absorption mode". The unit will provide 13.6 volts unless the load increases in which case it will return to the "bulk mode". While in the "absorption mode" if the unit sees no load on the battery for approximately 48 hours it will drop down to 13.2 volts and maintain the battery there until a load is detected. According to John 13.2 volts is perhaps 95% fully charged.
I asked John specifically if hooking up a brute force battery charger with the WFCO unit hooked up will damage the WFCO unit and he said it would not. If a battery is reallly dead, the WFCO charger (like many microprocessor controlled chargers) won't start the process and charge the battery) and you may need to hook up a brute force charger to get things going. I resurected a battery just last week (it was realllllly dead) by doing this. It only got up to 12.5 volts but it started the hydraulic unit so I could sell it. I did, though, tell the buyer the battery was suspect, a new one is twenty bucks, and he stole a $4,700 unit for $700 (but I paid $100 at a garage sale so I was happy). I digress.
I'm not sure who one should believe but my money is on John at WFCO. Too many "old wives tales" on the internet with no basis in fact.
Hope this helps.
Gus
mx842 wrote:I wanted to have an on board charger in the system just to be safe because you never know when something electronic is going to quit on you and it never hurts to have a backup. Also there is no reason it should bother the unit and I believe the e-bay guy was just saying that to get out of having to deal with it.
eamarquardt wrote:mx842 wrote:I wanted to have an on board charger in the system just to be safe because you never know when something electronic is going to quit on you and it never hurts to have a backup. Also there is no reason it should bother the unit and I believe the e-bay guy was just saying that to get out of having to deal with it.
I always like having an "alternate plan B" also and think a back up is good idea. I think I'd contact the factory about your failure and see if they will help you and I wouldn't do business with the EBay fellow again.
Good luck.
Gus
