8ft x 4ft CT to off-roader with two slide-outs - Year 1
Postby iSpy » Mon May 23, 2011 6:21 am
Well I started off with a 8ft x 4ft CT that has barn doors at the rear.
First I removed the corner iron work .... also the fibreglass arches.
A sheet of chequer plate was added to cover the old arches and new galvanized steel arches were attached.
I cut out the holes for the windows and side lockers.
Bigger lamps were fitted to the upper panel. The spare tyre was mounted on the rear door and a number plate lamp attached. (many parts came from Land Rover .... as that is what I pull with.
The large door on the left side is the access to the first slide-out.
Here is the slide-out box which allows for a single bed to be lay across the trailer.
a table pulls out from under the baed and forms the major part of the kitchen.
Well that was year 1.
iSpy
Postby glwt06 » Fri Jun 24, 2011 6:45 am
Your conversion looks great.
Any interior pictures? I'm interested in your slide out. I really like your use of the diamond plate on the sides.
Great name.
Nice work.
glwt06
Postby iSpy » Fri Jun 24, 2011 10:35 am
Checkout my other threads for interior photos
http://tnttt.com/viewtopic.php?t=44262
and
http://tnttt.com/viewtopic.php?t=44263
Good Luck
iSpy
Users browsing this forum: No registered users and 23 guests
