JJ92 wrote:While I wait for my trailer to be built, I have been pulling out the parts from the old travel trailer. Most of the expensive stuff is still in good working order, but I discovered that the black and grey water holding tanks are both cracked. Not just a little bit cracked, but major cracks. So I started working out how I could use the PVC pipe holding tank Idea that I have seen others on the forum use. I have a plan to use 6" PVC pipe for both tanks to get a respectable size tank. And as luck would have it, I discovered a seller on Craigslist that had 12' lengths of 6" pipe for $10 each.
That is what I'm planning on doing with 6" PVC slung under the trailer close to the axles. Figure on using the small hole expanded metal I already have for a rock guard. It won't catch dirt or trash but will deflect rocks that are kicked up by my tires.
