7x14 Snow Mobile Trailer
Posted: Mon Aug 18, 2014 9:49 pm
Hi all we picked up a 7x14 aluminum snow mobile trailer a few months back for moving stuff (military so we move a bunch) with a secondary plan of making a camper out of it. Empty weight is around 1.5K, and we maxed its (and our jeeps) GVWR on our move and it handled great, though getting the weight distribution hitch set up with the deep vee-nose took some time. We are living in New Orleans now, so number one item on the list is insulation and A/C if we hope to get any summer use out of it.
Idea/Question #1.- I'm thinking of trying to either do a canopy (ala coleman pop-up) or a rigid/foldable foam-ply structure (4-piece, a knee wall, 2 sides and a slant roof) to enclose the the ramps as beds. I have seen a few pictures on the net, but wasn't sure if anyone had attempted anything similar here. The ramp sizes will fit a queen in the back and a twin up front based on my measurements, and doing so gives me a ton more options on the interior.
#2-insulation, its all aluminum and I plan to look into quotes on spray foaming the interior and underside, but was curious what everyone's recommendations on insulation are. I'm a mech. engineer so I have a sound knowledge on thermo-dynamics and don't care to add a ton of extra layers to achieve a true thermal break (the ramp idea kills most of the isolation anyway) hence leaning toward having it sprayed. Not sure what the cost will be on that (anyone have experience there?) That said I'm also happy to just use a bigger furnace and air conditioner for the few occasions we'll need it. How has the single foam layers worked for you all? Any reason to use white vs pink style foam? I thought I saw over the top use denim insulation, any benefit on that over a rigid foam? I have extra head-room (6'6" or so) so I'll likely be dual layering the top regardless of the type of insulation I use.
#3-Fantastic vents- I hear nothing but praise about them. We have a seamless roof, I'd prefer to keep it that way. Just how good are they? Is it worth cutting into the roof for that & 2 anyone have experience with side mounting them?
#4-I'm leaning toward a dual vent portable heat-pump as I can get some use out of it in my garage, and can vent it out the side 'gas' door already installed on the trailer with zero head-ache until I decide on my actual usage and long term plans. I've seen mixed reviews and thought I'd take any input on them. My thoughts are if its actually designed and engineered well it should work almost as well as any other style, with slightly less power efficiency due to the intake/exhaust. I'm looking at this one, as its only one I could find that claimed it still worked down to freezing (most had an operating range NLT 50):
http://www.amazon.com/gp/product/B00DTV ... PDKIKX0DER
We had a heat pump in our last house which worked well but I'm not sure this can compare.
#5- Wiring: I'm leaning toward using wall mount wiring conduit over an in wall installation for a variety of reasons, with the exception of a few of the 12v devices (lights etc). Any pro's/con's.
That covers it for now
Cheers,
Alex
Cheers,
Alex
