Re: The Salt Block! 7x12 V-Nose SA
Posted: Sun May 22, 2016 9:35 pm
I have received all my supplies to wire my trailer! I am so excited!
I am in the middle of wiring so I can connect it all to my PD 4045. The AC side I have down. I will post pictures later. The DC side has me thinking a little more. I have:
standard 12 volt roof fan
3 ceiling mount 12 Volt LED lights (.45 Amps)
6 flush mount Undermount Puck 12 volt LED lights (.9 Amps)
A 3 in 1: two USB/Voltmeter/Car Charger, panel
A 2 in one panel Two USB/Car Charger panel
A Shurflow Water pump (7.5 amps)
Here is how I plan to wire the 3 Ceiling Lights with a switch on each light coming from the same fuse power line from the PD 4045:
Here is how I plan to wire the 6 flush mount Undermount Puck LED lights also using one single power line from the PD 4045:
I am puzzled how I will do the 3in 1 and the 2 in one. I believe I will do it just as I do the 6 LED puck lights above.
What do you all think?
Here are links to the two I purchased:
http://www.amazon.com/Atpmtas%C2%AE-Motorcycle-Digital-Voltmeter-Socket/dp/B013I22Y5K?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s03
http://www.amazon.com/Charger-Socket-Marine-Motorcycle-Outlet/dp/B00YX7AQOQ?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s03
As for the Solar Panel setup I think I am going to install a cutoff switch between both the PD 4045 and the Solar panel positive line. The solar positive wire cutoff for when I plug into Shore power and the cutoff on the Positive line to the PD 4045 for when I need to work on the DC wiring.
Suggestions and comments very welcome! I need them good or bad.
Thanks again!
Thanks again!
