Gunman9 wrote:I'm repairing the inside of my CTC. I thought about carpet. How much did it run you? I have a 6x14
EZDog wrote:Gunman9 wrote:I'm repairing the inside of my CTC. I thought about carpet. How much did it run you? I have a 6x14
Mine was $120 for a single piece long enough to do the entire trailer in one swipe.
34' for a 7'x10' trailer from Lowes.
Gunman9 wrote:EZDog wrote:Gunman9 wrote:I'm repairing the inside of my CTC. I thought about carpet. How much did it run you? I have a 6x14
I'm meant I'm painting mine grey with white trim at the moment. Do you have a name or link to the type of carpet used?
EZDog wrote:Gunman9 wrote:EZDog wrote:Gunman9 wrote:I'm repairing the inside of my CTC. I thought about carpet. How much did it run you? I have a 6x14
Not really I just went to Lowes and snagged it.
OK it says Eternal Slate on the receipt.
I have used this same carpet many times to cover walls and shelves and boxes,etc. and it is pretty nice but very light weight too.
It is easy to work and easy to clean.
This carpet is on a 6' roll luckily and that is about perfect for my trailer!
I am planning on trimming the top and bottom with wood and everything will be covered and they had to make a single cut to give me what I needed.
It was under $4 a linear foot 6' wide and they had it in Gray,Light Brown and Blackberry which is sort of reddish dark?
The Gray is pretty dark too,I mean relaxing of course.
Gunman9 wrote:EZDog wrote:Gunman9 wrote:EZDog wrote:Gunman9 wrote:I'm repairing the inside of my CTC. I thought about carpet. How much did it run you? I have a 6x14
Ok thanks. I think I know what it is. Similar to what's used on speaker boxes. Thanks for the help!
