Great build!
What bunk beds are those? When closed how much much do they stick out from the wall?
Do you have a picture of them set up?
Thanks!
Got them from Amazon. I just had to measure and decide how I was going to do it. Ended up with 15gal black tank the fit between the floor joists and a 38 gal gray tank that I had to cut one of the joist to fit it in. What I cut out I used to go joist to joist at the end of the tank so the floor wasn't soft. I think I showed it in the pictures. I still need to add water tank. To carry what I need I will probably use 2 tanks between the joists over the axles. Currently I'm city water only.LarryF wrote:AnthonyH, if you don't mind me asking where did you eventually find your holding tanks, what size did you go with and the price? I'm going with a 8.5x20 car hauler and my frame is also 2x6 and 2x3 tube steel on 16OC. Thanks Larry
