6X12 SS&S
Re: 6X12 SS&S
Postby featherliteCT1 » Mon Jul 31, 2017 6:15 am
I love that dog bowl!
featherliteCT1
Re: 6X12 SS&S
Postby Hader » Mon Jul 31, 2017 6:43 am
I had my doubts about the Tank-less water heater! I thought it would waste to much water adjusting to reach the right temperature.
Your experience is making me rethink my water set-up.
Glad it worked for you :thumbsup:
Hader
Images: 84
Re: 6X12 SS&S
Postby flboy » Mon Jul 31, 2017 1:22 pm
Did you get pics of the boondock? So glad you finally got time to work on your CTC. Almost done?
Don (Flboy)
YouTube Video of Finished 7*18 with 2ft V-nose Trailer:
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby m.colley » Tue Aug 01, 2017 5:11 pm
Like McDave, I have the Ecotemp L5 economy model and love it. Now I have mine hooked to work thru a converted shower box so I can have both hot & cold water inside and outside. Its close to being the best $ 100.00 I have spent on the trailer.
Martin
m.colley
Images: 83
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Aug 09, 2017 1:49 am
Some time ago I bought 7 feet of 4X4X.120 to make a bumper/leveling jack mount/stinky slinky holder.
After I bought the sewer hose I discovered that it didn't quite fit. :x After mulling over every possible
option under the sun, I decided to build a swage and make it fit. I had no idea how hard it would be to
pull an oversize chunk of metal through a husky length of square tubing. So I did a single bend on the
first time through. It went fairly easy, however, it took a jillion pumps on the jack to make it through (dern near killed me.)
Determined to only go through that only once more, I welded on a couple more chunks of iron to do the
remaining three sides in only one more pull.
The swage beginning its first pull. (Tubing was already bent on the lower left side. Nothing to do with this operation.)
The drawworks. Finishing the first pull.
The swage with wings added for second pull.
The now octagonish square tube.
Enlisted my son to help on the second pull.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Wed Aug 09, 2017 6:50 am
Wow.. seems like alot of work to make a hose fit. You must do this stuff for a living.
I would have just looked for a slightly larger square tube.
It looks great in any case! So professional. :-)
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby featherliteCT1 » Wed Aug 09, 2017 6:57 am
Iconfabul"8" makes me want to buy a welder and learn how to weld so i can fab and become Iconfabul"9".
featherliteCT1
Re: 6X12 SS&S
Postby onehoser » Wed Aug 09, 2017 8:52 am
must be a millwright :)
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Aug 09, 2017 12:16 pm
flboy wrote:Wow.. seems like alot of work to make a hose fit. You must do this stuff for a living.
It was a lot of work, but I needed to get it done. Didn't want a pipe. Don't think they make 4 1/2" square tubing.
To go to 5" my options were 1/4" or 3/16" wall thickness or order a whole length for $300. Thought about welding
up 4 pieces of 4 1/2" strap. That didn't sound like much fun or less work, plus I had the 4X4. As for my profession,
my grandfather was a fabricator, my father was a fabricator, my brother is a fabricator, and while I am not a professional
fabricator per se, I guess I inherited the gene. I consider myself more an inventor/maker. I build coin presses and vending
machines to make and dispense souvenir coins. http://Cointraptions.com
Not the best pic, but gives an Idea of what I do.
featherliteCT1 wrote:Iconfabul"8" makes me want to buy a welder and learn how to weld so i can fab and become Iconfabul"9".
Haha, :lol: Yes you should! "Iconfabul9" I like that!
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby FlyBye » Wed Aug 09, 2017 3:34 pm
Pretty Cool Iconfabul8!
FlyBye's 7x16 Cargo Camper Build
http://tnttt.com/viewtopic.php?f=42&t=69287
FlyBye
Re: 6X12 SS&S
Postby flboy » Wed Aug 09, 2017 7:32 pm
Thanks for sharing. That looks like a cool job. Do you fabricate the machines and parts as well as make the stamp designs? I have seen those machines before. :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Aug 09, 2017 11:48 pm
flboy wrote:Thanks for sharing. That looks like a cool job. Do you fabricate the machines and parts as well as make the stamp designs? I have seen those machines before. :thumbsup: :thumbsup:
Yeah I do it all. Kind of a one man circus, Haha. I am in a push right now to get the trailer to a point that the wife and I can go on a little business trip to Jackson Hole WY on the 21st and see the total eclipse in the process.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Aug 11, 2017 7:49 pm
Bumper gets a rattle can paint job.
Installed and ready to drag on a curb somewhere! :lol:
Also need to figure out an easy end cap of some sort.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby featherliteCT1 » Fri Aug 11, 2017 8:25 pm
I wonder if you could find a PVC end cap with a proper ID that would fit tight over the end? Also, RV stores sell square end caps
featherliteCT1
Re: 6X12 SS&S
Postby flboy » Fri Aug 11, 2017 9:26 pm
featherliteCT1 wrote:I wonder if you could find a PVC end cap with a proper ID that would fit tight over the end? Also, RV stores sell square end caps
I am sure he can Iconfabul8 one! :thinking:
Don (Flboy)
flboy
Images: 378
