6X12 SS&S
Re: 6X12 SS&S
Postby McDave » Tue Jun 21, 2016 5:27 am
Having that door moved back was an epiphany. That gives a lot more options for interior design. Way to use your noodle! :applause:
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Jun 24, 2016 1:22 am
Ok, it's been a few days. I have not wanted to post pictures until this particular project is finished. However! Here are a couple teaser pics. Any guesses as to what I am doing?
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby m.colley » Fri Jun 24, 2016 5:18 am
looks like a frame to mount a window ac possibly.
Martin
m.colley
Images: 83
Re: 6X12 SS&S
Postby flboy » Fri Jun 24, 2016 6:52 am
m.colley wrote:looks like a frame to mount a window ac possibly.
Martin
Yep.. Window.AC Mount. I need to build.one myself.in the next few weeks.
Is that being built in a way to have the AC in a cabinet and not extend out the side, or will it extend outside. I am building one to be internal with a intake in the ceiling and vent out the wall. I have never done this before,.so for me, it is learning by doing. Anxious to see how you do it. Way to innovate! :applause: :applause:
Don (Flboy)
YouTube Video of Finished 7*18 with 2ft V-nose Trailer:
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Jun 24, 2016 9:29 pm
With all the wood off the ramp and a big chunk of wood removed with the help of a router I began to cut a big hole in my ramp. Make sure your router bit is in tight and that you have the proper depth or you will end up with unwanted holes in the skin. I then cut a section of square tube. I was kinda spooked of going through the skin. Oh I should point out that my skin is glued on, so no taking the screws out and putting something between the aluminum and tube. With a grinder and a thin cutoff wheel I cut 1" away from the hole I wanted to cut to allow for a piece of square tube. I had to be careful not to go through the aluminum so I didn't cut all the way through. I came back about 3/8" and did the same cut. Then I cleaned out all the metal between the cuts, so now I have a wide slot with metal still on the bottom. I then went back over an inch where it wouldn't matter if I went through the aluminum and cut all the way through the square tube. I then cut on the original cut a little more but still not going through. Then I used some mig wire to cut the glue from the full cut to the original cut. This allowed me to bend the small piece until it broke and Voila (Wah Lah!) Didn't even have to get the grinder near the skin.
With the new tubes in place I was ready to weld them in. The dumbbells on lthe ramp keep it from slamming shut. Wont stay open without the wood.
Cutting the tube out.
The Roto Zip made short work out of cutting the hole.
Ramp is insulated and ready for the decking. The clamps are holding some flat pieces on the skin keeping it flat while some silicone dries on the new tubes.
Router worked great! I now have a hole in my ramp. Who would do such a thing? :roll: :thinking:
Filled the hole with this thing.
Built this.
View from the other side.
And put it all together. :)
View from the Right
View from the left
And Look! It opens!!
Ramp down
The reason I went this route was, all I will be hauling in and out can be done with a hand truck.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Fri Jun 24, 2016 11:05 pm
Wow! Nice Job on the AC mount. First time I have seen it done like that. :thumbsup: :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby m.colley » Sat Jun 25, 2016 5:58 am
Good job. Yes its different but it works and looks great. You've also given me a idea or two. Thanks.
Martin
m.colley
Images: 83
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Jun 26, 2016 12:06 am
The stud cutouts for my windows. Using the same technique with the wire, these cut out pretty easy. I think the glue is still drying since the trailer is so new.
Getting ready to weld in the headers and sills.
A shot of both window frames. They are 22" X 30"
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Mon Jun 27, 2016 9:14 pm
Niiiiice! :thumbsup:
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby hankaye » Mon Jun 27, 2016 9:57 pm
Iconfabul8, Howdy;
I must admit to a horrible case of tool, shop and wielding skills envy ... :envious:
hank
hankaye
Re: 6X12 SS&S
Postby Iconfabul8 » Tue Jun 28, 2016 1:41 am
First, I want to thank everyone for all the compliments :)
I got a little done today. The windows are all framed to size. I made these corner pieces with my modified Grizzly sheet metal roller.
I don't think the small transition (bump) into the curve should matter. Now as soon as I can get insulation in and boards on, I will router out the boards and Rotozip the aluminum.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby hankaye » Tue Jun 28, 2016 7:38 am
Iconfabul8, Howdy;
When you post "I made these corner pieces with my modified Grizzly sheet metal roller."
then show the great looking fit ... now yer just showin' off ... :roll: , :lol: , :thumbsup: , :beer:
hank
hankaye
Re: 6X12 SS&S
Postby flboy » Tue Jun 28, 2016 7:43 am
hankaye wrote:Iconfabul8, Howdy;
then show the great looking fit ... now yer just showin' off ... :roll: , , ,
hank
Lol. :-) that's funny!
But seriously, nice work! What a craftsmanship. I spent too much time in an office... I'd like to have some skills like that . It would come in handy for sure!
Sent from my SM-N900P using Tapatalk
Don (Flboy)
flboy
Images: 378
AC mount!!!
Postby Camp Wags » Tue Jun 28, 2016 12:22 pm
When I was scrolling through your build, I saw the AC in the rear door, and I said to myself,"Is that AC going to go flat when he opens the door!?" :shock:
Then I saw the frame standing and the door opened and thought, "Man this guy is bright!" "I bet he is so bright his mom calls him ,Sun!" :applause: :beer:
You got some good skills. Like your build. :thumbsup: :applause:
Gary
Camp Wags
Images: 57
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Jun 29, 2016 5:03 pm
Hank, but everyone else around here is showin off. 8)
Don, don't sell yourself short, I have been inspired by your builds. :thumbsup:
Gary, we won't talk about what my mom called me. :oops:
I did a little LED light testing. I bought a few to see what I liked.
1. This is the fixture that came with the trailer. I bought this LED replacement bulb for it. I was not really impressed. It wasn't nearly as bright as I was hoping a 68 led bulb would be. http://www.ebay.com/itm/301881412351?_t ... EBIDX%3AIT
2. I got this as a porch light. I thought if I liked it I might buy one for each side of the trailer. Front for hitching, truck bed, etc. Back for the ramp or backing up maybe. Left for bad guy watch.
These weren't bad, I will probably get more. I believe they are cheaper on Amazon http://www.ebay.com/itm/322047480583?_t ... EBIDX%3AIT
3. This was my pleasant surprise, with just a small row of leds I wasn't expecting much out of this thing. However, it was bright, has a warm light, I like it!! WINNER!!!
Link for single Link for double
4. I had high hopes for this thing, however it is peripherally bright and annoying, and doesn't shine out too far. http://www.ebay.com/itm/231313262723?_t ... EBIDX%3AIT
Iconfabul8
Images: 14
Users browsing this forum: Bing [Bot] and 10 guests
