6X12 SS&S
Re: 6X12 SS&S
Postby onlyridepark » Sat Jan 27, 2018 11:45 am
Iconfabul8 wrote:
onlyridepark wrote:Do you happen to have any pictures of your water heater vent pipe exit on the outside of the trailer?
Vent pipe install starts here
Sorry, I didn't go back far enough. Got to the beginning of plumbing and figured I missed it. You turned an eyesore into something that looks pretty awesome. Nice work!
onlyridepark
Images: 58
Re: 6X12 SS&S
Postby John61CT » Sat Jan 27, 2018 12:04 pm
That is a sweet DIY, reckon could put that on the market
John61CT
Re: 6X12 SS&S
Postby featherliteCT1 » Sat Jan 27, 2018 1:24 pm
McDave wrote:Only the coolest vent pipe exit, EVER!
McDave
Agreed ... I love that dog bowl!
featherliteCT1
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Feb 09, 2018 3:14 pm
featherliteCT1 wrote:Amazing! How do those supporting struts swivel?
I believe I misunderstood your question in my earlier response. The brackets that hold the glass in the upright position don't swivel, they are removed completely.
They slide in and out really easy. I will need to stow or hang them somewhere handy when not in use.
Glass Table Link
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Fri Feb 09, 2018 3:20 pm
McDave
Ditto!!
Don (Flboy)
YouTube Video of Finished 7*18 with 2ft V-nose Trailer:
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby featherliteCT1 » Fri Feb 09, 2018 3:22 pm
Glass Table Link
Thanks for the clarification ... again, that glass table is sweeeeet!
featherliteCT1
Re: 6X12 SS&S
Postby Iconfabul8 » Thu Feb 15, 2018 3:08 am
Hey, check it out, I finally took a few minutes and added a "Table of Contents" to my first post. I've seen a few of the Tear Droppers add them to their build page.
Looked like a great idea, so now maybe even I can find stuff without going through every page. :?
First Page and TOC
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby jr9744 » Thu Feb 15, 2018 7:43 pm
Iconfabul8 wrote:I am kind of excited about this project being done. It was kind of a wild Idea but I think it worked.
I started by ordering a couple pieces of tempered glass, and a couple sets of glass hinges, and building
3 little bars that I mounted to my chair rail.
Glass link
Hinge link
Put it all together and it is my fold down table/tables. If you are having a hard time seeing them, then they are doing their job.
I didn't want to hide the wall with an ugly table.
Tables in the up position. Built braces that slip in from underneath.
Front table is 32"x14" back table is 24"x14"
Bottom view.
I love the way you did your walls. It all looks great!
7x7x16 V Nose Travel Trailer, First Build...In Progress
http://www.tnttt.com/viewtopic.php?f=42&t=68569
jr9744
Images: 311
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Mar 04, 2018 2:03 am
jr9744 wrote:I love the way you did your walls. It all looks great!
Thanks, I am enjoying your build as well.
Started fabbing my overhead luggage/storage rack.
Cut and pre drilled a piece of 1/2" baltic birch for the bottom.
After determining where the rack goes, I cut the molding and did a little wildcat drilling to find the roof bows.
I got spooked that just one #10 metal screw into each of 3 roof bows was maybe a little shy.
So I built these pieces to get 2 more screws in each tube. Notice the slight angle cut, this will match the roof slope.
Welded the screw tabs on. 9 screws ought to do the trick.
In the process of lacquering the board. "Why am I floating and everything is spinning" :) :FNP
There she is all mounted. The wall studs were much easier to find since one was exposed from the window cut out.
And YES I plan on getting a more manly sheet for the mattress. :oops: :lol: Hopefully finish up the rack Mon or Tue. Stay tuned!
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby hankaye » Sun Mar 04, 2018 9:22 am
Iconfabul8, Howdy;
You do such excellent work, always impressed when I view one of your posts. That said ...
How are you gonna soften those corners ya got hangin' down in the middle of the trailer now??? :thinking:
hank
hankaye
Re: 6X12 SS&S
Postby McDave » Sun Mar 04, 2018 12:06 pm
Iconfabul8 wrote:And YES I plan on getting a more manly sheet for the mattress. :oops: :lol: Stay tuned!
Well, don't do anything rash now. There's no mistakin' that's a manly trailer, with the wood and exposed steam punk utility center, and the tin roof wainscoting. And besides that, looks like you could get some pretty sweet dreams with sheets like that..... just sayin'
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Hader » Sun Mar 04, 2018 12:16 pm
Fine work. :applause: :applause: :applause:
Hader
Images: 84
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Mar 04, 2018 3:11 pm
hankaye wrote:Iconfabul8, Howdy;
hank
I think it's going to be OK, It is clean over the wifes head and I guess if I tangle with it too often, I will chop off the corner.
The right side is the only one that has any potential to be in the way. I still have a microwave shelf to mount on the right side.
That should help in keeping some distance from the corner.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Thu Mar 08, 2018 2:32 am
This section of the shop was a bit chilli, Broke out the Propane heater to help dry the lacquer.
For a little practice and experience I had my son cut out and weld up the parts for the microwave shelf.
Turned out pretty good. (He's 16)
I haven't used a coping saw in ages, but it was the perfect ticket for this little notch job.
I think, sometimes we get so dependent on power tools we forget how to use hand tools. :hammerhead:
The microwave shelf bracket is all mounted.
Shelves are up and covered, yay! Not sure I will do any doors. If I do, it will be a swing down half door across the whole front.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby MrBo » Thu Mar 08, 2018 6:58 am
Nice work! Love it!
Mr Bo
6x14 Build Log - Rolling Thunder - Cabin on Wheels - http://www.tnttt.com/viewtopic.php?f=42&t=69971
MrBo
