6X12 SS&S
Re: 6X12 SS&S
Postby racerrandy » Tue Mar 21, 2017 8:46 pm
Really loving the build, thanks for showing us what your doing. Pics make all the difference in understanding things!
Randy
racerrandy
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Mar 22, 2017 11:53 pm
Started on the bathroom wall yesterday.
Got'er all framed up. I promise the walls are straight. I was using my cheapy china wide angle phone lens.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Sat Mar 25, 2017 3:24 am
I bought the trailer with the interior molding uninstalled. So I was given a pile of bent corner molding/flashing.
Tonight I put my first piece up.
I am not a huge fan of Harbor freight tools, But this little hand punch has been really handy. It punches this stuff like butter.
I used an end drop to make a pattern. Trim and fit it, then transfer to full size piece.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Apr 09, 2017 2:37 am
In order to get my shower stood up in the trailer I had to cut one of the flanges off. It also needed to fit under this valance/thing. Well The gap ended
up being about a 1/2" and kinda ugly. So today I tackled the shower molding project I have been putting off.
I traced the shower edge onto some cardstock that I taped together, I then bent this piece of aluminum to fit.
By cutting off the flange of the shower, the shower wall was kinda floppy. So I made this wild confabulation. It is a 1/4" self tapping screw welded to a long
coupling nut. The all thread is then double nutted in very tight.
I made a small slot in the shower, then chucked the all thread thing up in the drill and screwed it into the sheeting and tubing in the front wall.
Before I slipped this thing behind the wall I put a nut and washer on loosely that I was able to run up against the back of the shower wall.
Put on a little copper paint. Cut off the all thread with the dremel and put on a pretty little acorn nut (and a few stainless screws.)
I am happy to announce that it is now anchored quite solid.
Another shot of some molding, paneling and flashing.
I had to hog out a wire path before putting up the bathroom wall paneling.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Hader » Sun Apr 09, 2017 5:58 am
Good to see you back at it Iconfabul8 :thumbsup:
Starting to look real nice.
Hader
Images: 84
Re: 6X12 SS&S
Postby McDave » Mon Apr 10, 2017 10:34 am
:applause: :thumbsup:
Adapt and Overcome, I like it.
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Apr 23, 2017 2:42 am
First off, Thanks Don, Randy, McDave and Hader for the Thumbs Up. :) I got a little bit more done today. "Yay"
Taped a couple poster boards together and scribed the ceiling. You have to look kinda close to see the pencil line.
Cut the line on the poster board and traced it onto this ridiculously expensive piece of prefinished 3/4" birch.
Needless to say I measured more than a few times before I cut. :worship:
Built this temporary router guide.
Got the board stood up in place, put a few screws in. The blue tape was to show me where to put the screws. And routered out the doorway.
Fat man routering a doorway. Routers are so awesome! :o
Put up a few more pieces, more routering and PRESTO my wall is covered! :applause:
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Sun Apr 23, 2017 2:58 am
That's some nice clean work on that wall. But that panelling is beautiful! What is that?
That is starting to be a pretty sweet rig. Keep that stuff up.
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby Hader » Sun Apr 23, 2017 7:37 am
Wow! :beer:
Hader
Images: 84
Re: 6X12 SS&S
Postby hankaye » Sun Apr 23, 2017 9:54 am
Iconfabul8, Howdy;
Bravo!!! Dang, you do good work! The best part to me is your matching both
pieces of the door-way to look like a single piece.
:applause: , :applause: .
hank
hankaye
Re: 6X12 SS&S
Postby flboy » Sun Apr 23, 2017 7:05 pm
Awesome craftsmanship! :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Sun Apr 23, 2017 8:13 pm
McDave wrote:That's some nice clean work on that wall. But that panelling is beautiful! What is that?
McDave
It is some stuff I picked up at Home Depot but I wouldn't recommend it. I bought it hoping
it would add some structural strength being that it was 3/4" plywood. But the stuff is warpy,
soft, and the veneer is super super thin. Also the bright halogen work light brings out a lot of that curly birch grain.
hankaye wrote:Iconfabul8, Howdy;
hank
I have to confess that the picture hides the seams. It doesn't look this good in real life.
Thanks guys,
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby HouTX » Mon Apr 24, 2017 5:59 pm
Iconfabul8,
Thank you for your efforts in posting pics and details. As someone looking for ideas on this site, your personal hygiene area provides a good visual for what I have in mind. Can you provide info on the exhaust fan you have in your "library" area? Anything that will help look it up online.
HouTX
Re: 6X12 SS&S
Postby Iconfabul8 » Mon Apr 24, 2017 7:49 pm
HouTX wrote:Iconfabul8,
It's a Ventline #VP543
http://www.ebay.com/itm/Ventline-VP-543 ... rw&vxp=mtr
https://www.etrailer.com/RV-Vents-and-F ... AhVu8P8HAQ
https://www.amazon.com/Ventline-VP-543- ... s=VP-543SP
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Apr 28, 2017 3:36 am
Here is a little short story for ya.
The slip fitting in my black tank's vent hole was too big. Every fitting I tried in it was sloppy. I didn't dare just glue it.
I kicked around epoxy, but I didn't want to wait around for two days for a test to dry. Anyway I settled on a method a friend
had told me about years ago. I took a scrap piece of abs, clamped it in the vice. Built this lovely cardboard fixture to catch
a bunch of fine shavings that I ground off with my awesome Roto-Zip.
Poured abs glue over the shavings, mixed until it melted all the abs into a thick paste. The picture is what was left after.
Smeared it all over both pieces and shoved it in the hole. I guess time will tell.
Thought I would just slip this one in. If you were having doubts about the usefulness of a philips screwdriver, this is the best use I have found.
Seals the end nicely!!
Iconfabul8
Images: 14
