OP827 wrote:Oh, forgot to mention that I am shopping for up to 20000btu, direct vent type as I build a relatively small trailer, 6.5'x14.5'
Iconfabul8 wrote:Has anyone considered using one of these? They look like they could be nice. Vented and requires no power.
http://www.landmsupply.com/department/home-improvement/heating-and-cooling/propane-heaters/ventless-heaters/us-stove-direct-vent-lp-heater?utm_source=google&utm_medium=shopping&utm_campaign=google_base&gclid=CJT_ttSSrdACFQiOaQodijUILw
retep wrote:My Dad put something similar to that direct vent furnace in his garage. It was perfect. I am in Toronto Canada and it kept the insulated garage a very comfortable 55*f so we could work comfortably, and it was set to low. I was thinking of using something similar if I move ahead with a CT. I really enjoy this style of furnace, The only thing I would consider is the amount of Real Estate it takes on a wall.
Cheers Peter
Hader wrote:I have used one similar to this: http://www.northerntool.com/shop/tools/ ... _200664865
the trailer was 32' x 8 1/2'.
OP827 wrote:Hader wrote:I have used one similar to this: http://www.northerntool.com/shop/tools/ ... _200664865
That is a nice little unit, Hader. Is this a ventless unit that burns air and exhaust inside the trailer? Or it has a direct vent from/to outside? If it ventless, then the breathing air inside will have less oxygen and gradually more CO2 or even CO and then more moisture too. Opening some window gap is a safety requirement, right?
Sorry I failed to mention in my initial post that I am also concerned with oxygen depletion, so I am looking into direct vented units, when burned gas and fumes are isolated or vented from the trailer interior, like in furnaces or heating stoves.
