Gladtobehere wrote:I just removed and reinstalled a similar Dometic rv fridge. It seems to me that the two holes at the bottom ,rear of the fridge and the front trim angle pieces are all that are used to hold the unit secure. My camper is 12 years old and those fasteners have held fine so far. In fact the rear screws where basically doing nothing at all so most of the stability came from the frnt trim.
That is interesting. It is similar to what I saw on bigger RV fridges replacement videos where the front rim had screws through the face rim to attach to the opening front frame. So the front rim of your fridge had holes in it with screws?
Let me summarize once again: your fridge front rim had screws attached to the face frame and there are also two screws on the back bottom (those two are mentioned in installation instructions). And then there is more screws in the rear of the fridge, where are they?
My used fridge came from an hotel and it does not have any holes on the front or back except the ones mentioned in the installation manual. I know that my trailer suspension feels pretty stiff so far, so I may be considering adding some more screws... How many holes in the fridge front rim and then back do you have?
Thanks for help!
Oleg
