Hey MXD,
I have the Coleman Mach III with the heat strip. It works really well as a cooler and it has a Cool hi/low fan speed, hi/low fan only option and low heat setting. As for the heater, its only about 1500 watts and you seem to lose some of that to the machine and the fact that it is not air tight between the compressor/condenser side and the evaporator/heat strip side. Also the heat comes out at roof level, and since heat rises it takes a while before enough air has cycled through to feel the heat if you are sitting. Stand up and you've got a hot head. But if you just need to take the chill off, say it's 50f inside, this will work nicely. As I write this, it is -4f and we are hoping for a high of 7f today. Balmy for Montana, but the heat strip would be basically useless now. I have a little ceramic heater that is only1100 watts with a fan and it works much better.
This is the only rooftop A/C I have any experience with so I cant speak to the Dometic or Atwood. 135000btu is plenty. We're only talking about 100sqft or less and I have it well insulated. Dollar for dollar the best thing you can do is paint the roof with Henry 587 Reflective roof paint. About 35.00 per gal., covers 100sqft, double coats. The difference was remarkable. Like 35 degrees in July.
The A/C fan is a little noisy and since it located at head level when standing, there is no avoiding it. but it does cool it down quickly.
Seems like it weighed 100-125 lbs. I used 1.25 square tube welded in around the 14 x14 hole where the roof vent was.
It is nice to have it located on the roof since space inside is limited to begin with, keeps it safe and out of the way. IMHO, the right tool for the job. The window A/C idea works, somewhat, but you get what you play for. Just sayin'
Hope this helps,
McDave
PS. Here is the install PDF....
http://www.1willwander.com/2013/07/cole ... ation.html
