by yycwrangler » Thu Feb 16, 2017 1:57 am
Hi Raider
I just put an order in for a Neo last week. Delivery date 2 week in April which is fine with me. Looks like we ordered a lot of the same options. I also added a RV door which comes with a screen door and also the pullout step for the side door. My unit is a 6x12 round. 3 - 30x30 windows, 2 on drivers side, 1 on passenger side. Vinyl interior roofing with a cover for the spring for the ramp. I also went radial instead of bias ply and installed a rooftop vent and will install a maxxair eventually. It wasn't cheap about $6500 US but had all the options I wanted. As I'm in Canada, one of the biggest costs I had was shipping. About $1200 US to Saskatchewan which is the closest dealer to Calgary (about 6 hours away). But that price includes all the paperwork to get it across the border and certified. So if your close to the manufacturer location you could knock off about $1200 from my price which isn't bad.
make sure you get them to use screws on everything which makes it easier to remove roof and walls for insulating. They also have a 3" trim which hides the mating of the plywood, they usually staple that on, so I asked that they cut to correct size but don't attach. just leave in trailer. I understand it's tough to remove the rim when it's stapled.
look forward to seeing your build.
Cheers
Al
Calgary
