by McDave » Mon Mar 06, 2017 1:25 am
Hey Al,
I didn't use the "puck" style, But I have 2 Led fixtures that have dimmers. They resemble traditional RV fixtures, but LED and dimmers on/off. 1 in cargo area, center of ceiling, 1 in galley area directly above door. Both are wired to a main switch, also located above door, and a 2nd main located at rear on the side of ramp frame. 3 way so either switch can turn on/off.
Also, I have a total of 40 ft of LED strip lights, "warm white" color, that also have a main sw. above door, and are on dimmers with remote controls. I'm a big fan of indirect lighting, and my trailer is only 6 ft high, so ceiling lights can be harsh. I put 16 ft of strip at mid height each wall in cargo area, hidden behind a handrail, 8 ft facing up, 8 ft facing down.
The light "washes" the wall and lights up the ceiling and the floor but you don't see the LEDs. There is another 8 ft total in galley. 4 ft across nose at ceiling running from door to fridge, (eyelevel) 2ft under fridge/ above sink, and 2ft under sink counter top above "bar". They are very effective and comfortable. They draw less than .4wt per ft @ 100%. About 15wt for all 40 ft @ 100%, but I rarely have them over 25% and mostly at 5-15%, about 2wt per hr. I have no windows so this the only light source and it works great. The over head fixtures I only use for task lighting. The strip lights and dimmers are unbelievably cheap on EBAY, so I ordered lots of backups and replacements but so far zero problems.
McDave
