Spaceman Slumber up bed
Postby mrwall1 » Mon Apr 24, 2017 7:27 pm
Somebody posted this on the facebook cargo trailer site...
https://www.youtube.com/watch?v=kNIKy_I15W8
Pretty pricey at over $7000
but seems like there would be a way to make one similar.....
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Re: Spaceman Slumber up bed
Postby McDave » Mon May 01, 2017 11:57 am
Now that is cool!
Thank God hiphuggers are back!
Oh, and did you see the way the bed was counter weighted similar to the way the old windows worked? You'd think someone round here wood'a had that idea......hmmmm
"Re: HappiJack alternative? Vertical bed lift
Postby McDave ยป Fri Mar 31, 2017 5:26 pm
Here's a concept I haven't seen explored, Why not use sandbags or similar weights to counter bed weight to a neutral state?
Same concept as the old window weights where there was a pulley at the top and ropes attached to window, around pulley and hanging in chase. As window goes up, weight goes down and it holds at any height. You still need some sort of track to keep the bed securely located and locked in up/ down position. Thoughts?"
just sayin'...
McDave
McDave
Images: 412
Postby Aguyfromohio » Mon May 01, 2017 1:29 pm
Counterweights work perfectly, but they double the weight of the system every time, by definition.
Might be a better solution for stationary things like houses than for vehicles.
Aguyfromohio
Images: 76
