Shadow Catcher wrote:I used the plastic mounts, which were not available in the US at that time so I imported them from China. Not wanting to drill holes in the roof I had a long discussion with a 3M engineer and he was able to steer me to the correct VHB tape and how many square inches I would need for the wind loads. I followed exactly the directions for prep and placement. Wind loads have been in excess of 140 mph. I found tamper resistant bolts/screws not in the Harbor Freight tamper resistant driver set. The panel, intended for a grid tie system puts out better than 70V no load and better than 30V shaded. fed in to a Morningstar MPPT Sunsaver controller.
tanukihimself wrote:needing a solar panel or 2 for my setup and im not really digging the idea of having them hard mounted to the roof of my ct. So my thought was to have a movable setup that i can place away from my shady camp spot, like a tripor or something, and just get a longer cord for the panels. My question is how can i make the tripod and panels LESS stealable? I know nothing is theft proof, but doe any of yall have experience with this situation? Could i just run a damn logging chain from a tree or my camper to the tripod? What about the actual panel? Locking nuts?
Any ideas?
lrrowe wrote:Don, your cross bars is where my head is at for my method right now. My roof to siding is curved so, I would like to fabricate a side bracket that flows with the curve for aesthetic reasons. Something like OTTCT did. I would post his photo if I could.
flboy wrote:lrrowe wrote:Don, your cross bars is where my head is at for my method right now. My roof to siding is curved so, I would like to fabricate a side bracket that flows with the curve for aesthetic reasons. Something like OTTCT did. I would post his photo if I could.
You could get the flexible panels to conform to the curves , in which case, I'd have no problem glueing those down. Not really anything to catch the wind. The flexible type are a little more expensive, but they would solve the aesthetic issue for sure. :-)
