Page 14 of 14
Re: 7x16x6.5 Featherlite Build
PostPosted: Wed Jun 19, 2019 3:27 pm
by featherliteCT1
Thanks Hank :D
PostPosted: Fri Jun 21, 2019 11:05 am
by McDave
Hey Featherlite,
I think you are on to something here. I can see some advantages to having the battery/solar bank in the tow vehicle. Weight distribution, access to the batteries and panels, mobile power station that could power other needs or trailers, and the fact that you could in theory park the truck in the sun and the trailer in the shade could be a boon. I tow with a 3/4 ton van so it is similar in shape to your truck w/topper. I have been considering a "wing" to deflect the air over the trailer and some sort of vortices generator to break the suction at the ramp door when towing. If you can get the same effect via tilting the panel, that's a two fer!
Nice work Mister. You have given me something to consider when I add solar to my unit. (soon I hope)
McDave
PostPosted: Fri Jun 21, 2019 5:27 pm
by featherliteCT1
McDave,
I have benefitted from the advantages you listed, especially with no need to take up space in the trailer and the ability to park the trailer in the shade with the truck in the sun.
I made a 20 feet long “extension cord” out of 2 AWG wire with Anderson plugs on each end to connect the truck to the trailer. I bought a 20 feet long set of jumper cables for $20 at Rural King to source the 2 AWG wire, which equates to a cost of $.50 per foot. The wire is copper with an aluminum cladding with the effect that the wire is probably equivalent to about a 3 AWG pure copper wire. At the amps I draw (no more than 10 amps), I experience negligible voltage drop. I suspect I could even go up to 40 feet with acceptable voltage drops (say 2%).
PostPosted: Mon Jul 29, 2019 2:40 pm
by featherliteCT1
When it rains I cannot open my slider windows so I fabricated two rain covers out of scrap 1/4” plywood as prototypes to see if they will keep the rain out while still allowing sufficient air intake. The opening at the bottom of each cover is 4”x ”28”= 112 sq. inches of opening.
I slapped on some oil based paint I had laying around to make the covers halfway presentable and to protect the wood.
I attached an aluminum angle above each window with 3m VHB tape so that the angle is removable without marring the skin of the trailer. I laid a bead of silicone caulk at the top seam where the angle meets the skin hoping to prevent water from possibly degrading the VHB tape.
I attached an eyehook at each end of the angles and on each side of the covers.
I laid a bead of clear silicone caulk around the edges of the covers that make contact with the skin to prevent marring the skin.
A turnbuckle hooked to each end of the cover and to each end of the angle holds the box up tight under the angle or alternatively, allows creation of a slope to shed water to the front or rear of the trailer, depending upon wind direction.
It is supposed to rain tonight with 20pmh winds so I might sleep in the trailer tonight to test how these covers work.
I used 6 screws to make each cover which will enable me to take the covers apart and store them flat. I suspect it will only take about 5 minutes to assemble and install, likewise to remove and disassemble, give or take a minute or two.
I am hoping that my Maxx Air fan will exhaust out strong enough to prevent rain from entering through that roof vent.
Below are pics.
Rain cover Box side.jpeg (306.38 KiB) Viewed 1707 times
Rain Cover Box bottom.jpeg (330.8 KiB) Viewed 1707 times
Rain Cover Box front.jpeg (285.68 KiB) Viewed 1707 times
PostPosted: Mon Jul 29, 2019 2:45 pm
by featherliteCT1
Here is a pic showing where I wedged some wood braces up against the angle to put pressure on the VHB tape to increase adhesion as the tape cured. I parked my trailer close to my barn so I could use the barn wall as a base to push from. The skin was fairly hot so I think it will adhere well enough for the intended use.
Rain Cover Box brace.jpeg (71.04 KiB) Viewed 1706 times
PostPosted: Sat Feb 08, 2020 1:48 pm
by featherliteCT1
I just purchased and installed the new Bogart WF 2030 wifi unit that transmits data from my TM 2030 battery meter and my SC 2030 charge controller. Now I can read all battery data and reset any of the charge parameters remotely. I can do so on my phone or laptop or any other device with a web browser.
The WF 2030 is the black unit.
200209 WF2030 TM2030.jpg (330.48 KiB) Viewed 1231 times
Below are two screen shots from my phone. One screen shot shows current data, the other screen shot shows all my charge parameters,
For me, this is the cat’s meow.
WF 2030 unit cost $99 and was simple to install.
200208 WF 2030 Data.jpg (643.97 KiB) Viewed 1224 times
200208 WF 2030 Parameters.jpg (951.46 KiB) Viewed 1231 times
PostPosted: Sat Feb 08, 2020 1:50 pm
by featherliteCT1
Below are two two screen shots showing History data (I just reset all history data so no prior history data available except for today’s data).
200208 WF 2030 History 1.jpg (656.84 KiB) Viewed 1231 times
200208 WF 2030 History 2.jpg (595.38 KiB) Viewed 1231 times
