Tried to get a hold of Coventry kid who has done this but he is unavailable at the moment. has anyone else mounted their spare tire to the lower portion of their ramp (outside)..If so, care to share any pics as I would love to do the same
Cheers
Al
hankaye wrote:yycwrangler, Howdy;
The mounting bracket that came with my trailer, still to figure out where it will call home,
is like this one only for 6 hole pattern.
http://parts.trailersplus.com/tire-moun ... t-pattern/
I'm sure that you could make one yourself for less cost if you want. Mount the flat strap
on the inside and ensure the bolts are long enough to mount the spare on it. I would also
solidify the area for mounting with something like a piece of 2X4 or something like that to
keep the sheetmetal from bearing the weight on the outside. Make strong ... like rock
hank
PS. you've got this running with a duplicate thread.
McDave wrote:hankaye wrote:yycwrangler, Howdy;
hank
@ hank,
If I'm reading that right, they intend for this to bolted to a wall stud in the vertical axis, correct?
McDave
