Thanks for the feedback hank. I am concerned about chafing and will reevaluate contact points with the tank. The tank is secured laterally fairly well by the brackets and the wood frame/plywood wall. Can you elaborate on your belt and suspenders idea please?hankaye wrote:Viper_Twig, Howdy;
My main concern would at the bottom of your securing set-up.
The vibrations from the road will have a dark spot rubbed onto
the white spun plastic water tank and those screw heads will
rub right into the liquid a lot faster then you may think. Chaffing
strips between anything and the tank. Better safe then sorry.
Said it before, I'm kinda a belt and suspenders type when it comes
to things like this.
hank
Good idea, I can easily do that with some scrap plywood I have laying aroundfeatherliteCT1 wrote:Neat idea!
I am wondering if you should also put a strip of plywood over the rubber strips spanning the entire width to prevent the clamps from poking into the plastic.
Viper_Twig wrote:Thanks for the feedback hank. I am concerned about chafing and will reevaluate contact points with the tank. The tank is secured laterally fairly well by the brackets and the wood frame/plywood wall. Can you elaborate on your belt and suspenders idea please?hankaye wrote:Viper_Twig, Howdy;
hank
Cheers
Hahah gotcha. I was trying to figure out what kind of belt and fasteners was going to hold my water tankhankaye wrote:Viper_Twig, Howdy;Viper_Twig wrote:Thanks for the feedback hank. I am concerned about chafing and will reevaluate contact points with the tank. The tank is secured laterally fairly well by the brackets and the wood frame/plywood wall. Can you elaborate on your belt and suspenders idea please?hankaye wrote:Viper_Twig, Howdy;
hank
Cheers
Belt & suspenders goes back to the old farts that would wear both, just to be sure their trousers wouldn't drop unexpectedly
can also be used to refer to using a little more _____ (fill in the blank), to get the job done and be sure it works correctly.
hank
Viper_Twig wrote:Thinking about tackling the water and electical inlets tomorrow. Any advice? I got long #8 stainless bolts and the appropriate size hole saws. The 30amp and city water seem straightforward but I'm concerned about the non pressure water inlet. It is tapered. I was going to drill a 3.5" hole through the sheet metal and a 2" though the plywood.
Cheers
Yessir that is true. Thanks!Iconfabul8 wrote:Well if you are anything like me you get the most done while under pressure. Great looking lp tank mount by the way
