low277 wrote:Nice trailer!!! I like the color!
Thanks! Good luck with your project. Between work and family vacation not much more construction progress to report. But I have finally received my windows and ordered almost every component for the build. Hopefully more time for building soonbmneilson wrote:Looks great! Have you made any more progress since insulating? I just purchased a nearly identical 6x12 with a shallow v nose, a little older but I'll be on the same track as you! Although I did take it all apart today and found the previous owner had insulated and wired it up partially for me
Congrats! I'm looking forward to connecting everything soon too. I shopped around a lot for a battery mounting option. I was originally going to put them inside and vent but ultimately decided to keep them outside. For the limited space I have on my v-nose tongue this box fits perfectly, unlike the cheaper plastic options out there. It's expensive, but I couldn't get a local metal fabricator to make me a similar one out of aluminum for cheaper. The box looks very well built and it is very light (until I put the two 6v batteries inside) which is important because my build inherently concentrates weight up front that I will have to ballast aft of the axles.Iconfabul8 wrote:Nice battery box I saw these awhile back and lusted over them. I just got my batteries mounted and usable, it was a happy day.
Viper_Twig wrote: my build inherently concentrates weight up front that I will have to ballast aft of the axles.
Sent from my SM-G935V using Tapatalk
