Builder-Billiam wrote: And to try to get ahead of why I don't just want a roof unit, I just personally don't like them as well. I know my 2000 watt inverter will power up and run a 6,500 or maybe even a 8,000btu
window ac but it will not do a 13000 roof unit. Also I think the 8000 wall unit will POSSIBLY cool better than the 13,000 roof unit.
NO David! wrote:This should prove interesting to you, my version is in there too.
http://www.tnttt.com/viewtopic.php?f=42&t=49438#p920256
look at iconfabul8 for his inside ramp door mount.
m.colley wrote:Builder,
There's been alot of discussion on this forum about AC installs, hacks, ideas etc. Some of us like the roof top units, some window Ac's and there's a few here that cool their trailers with mini splits. Some members prefer one unit over the other.
My 7x16 is cooled by a 8000 btu window unit and cools nicely. Yesterday it was 91 degrees outside@ 5pm and 89 inside the CTC. The window unit pulled it down to 74 in a matter of hours and was cycling on and off. So I know a 8000 should cool yours nicely. Install will be the difference.
You'll need both intake and exhaust openings if you don't cut a hole and stick the back out of your CTC. Size your holes based off of the square inches of louvers your window unit has from the factory. Remember heat rises naturally.
Martin
Builder-Billiam wrote:Whats up with you McDave?
I don't get your sarcastic response. I have had two roof unit 13000 btu units that performed pretty bad where as I PERSONALLY have not had any bad experiences with the little 5k-8.5k window units.
I apologize for making the assumption that we were all adults here and that one was able to ask a question without being ridiculed. Hope you have a nice day McDave !!!!!!
To other members...........Is this normal behavior for this forum?
