Roof seam sealants
Roof seam sealants
Postby fourbtgait » Fri Jul 14, 2017 8:55 pm
Not looking for new ideas, wanting to know if someone has an idea of the stuff cargo trailer manufacturers use on the roof to seal seams, vents.
Almost like a pourable material?
Pulling my vent to install a power vent and I like what the manufacturer used (Continental Cargo, Forest River)
Sticks nice but comes up easy with the proper scrapper.
fourbtgait
Images: 16
Re: Roof seam sealants
Postby John61CT » Fri Jul 14, 2017 9:38 pm
Butyl tape?
John61CT
Postby fourbtgait » Fri Jul 14, 2017 9:52 pm
No, its a semi fluid material that they seemingly squirt or pour on seams.
fourbtgait
Images: 16
Postby M C Toyer » Fri Jul 14, 2017 11:29 pm
You're looking for a self-leveling sealant - available in various formulation such as silicone, urethane, butyl, etc.
It can be applied with small squeeze tubes, caulk guns, or poured from bulk containers. Window manufacturers typically use pressure guns or manual squirt cans.
I've used OSI Gutter Sealant. You should be able to find all products at most hardware or home centers and some auto suppliers.
M C Toyer
Images: 11
Postby CoventryKid » Sat Jul 15, 2017 12:14 am
Dicor self leveling sealant but I'd bed the fan in butyl tape first, then screw it in place, then Dicor over edges, screws, etc.
That's what I did with my Maxxair fan 3 years ago. No leaks.
Hope this helps.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
