Its hard to know really what level of finish you are going for overall but it is not a great distance from front to back usually in these trailers so I am not sure how much prep for running wire later you really need?
Any open loom tray will be visible from what you say?
I would run "Smurf" tube which is a non-metallic conduit ,probably between a few small boxes along the side where I might want to go across the ceiling down the road.it is easy to work with and to find and pretty cheap but reliable and protective of the wiring too.
Here is an example of a prewire for a 75" TV on an articulating arm mount that I did where I ran wire that I knew I would need but also ran the tube for anything later that might come up.
If you think you will need vertical runs later then you can bury it in the wall too right next to insulation and you can also run it outside under the floor later if you don't put it where you end up wanting it!
It is also pretty easy to Fish wire later in such a short distance to me.
