Page 8 of 21
Re: Intro and title, “motobox that my wife would camp in”
Posted:
Sat Feb 01, 2020 8:00 am
by hankaye
BigDave_185, Howdy;
buytal tape, works fine ...lasts a long time.
Handling tip, if it's warm where/when you want to install the buytal tape
put it in the freezer for a while first, otherwise it gets to soft n saggy.
hank
Posted:
Sat Feb 01, 2020 12:19 pm
by BigDave_185
How warm are you talking.? Outside air temp is about 35 today but the garage I keep at 65. Also need to sheet walls today before i get windows back in
Posted:
Sun Feb 02, 2020 11:50 am
by hankaye
BigDave_185, Howdy;
, Just another one of those warm winter days in Utah eh?
Throw it outdoors, bring it in when ready to apply it.
Generally if your comfortable in a T-shirt it can use some cooling down.
Just makes it easier to handle is all.
hank
Posted:
Sun Feb 02, 2020 12:44 pm
by BigDave_185
Copy that
Any once have suggestions for transfer it the cut outer wall of the window to the sheeting I just put back up on the inside?
Posted:
Sun Feb 02, 2020 8:23 pm
by BigDave_185
Posted:
Sun Feb 02, 2020 8:59 pm
by pchast
I think my approach would be to lightly attach the inner sheathing and
scribe it from the outside before window installation...
Posted:
Sun Feb 02, 2020 10:05 pm
by BigDave_185
So I just re read my last post. Oh boy th at was bad!!!
So I took the vibe saw and cut it out. Then made my hole bigger
Posted:
Sun Feb 02, 2020 10:08 pm
by BigDave_185
And he passenger side is re sheeted,
Posted:
Sun Feb 09, 2020 9:39 am
by BigDave_185
Well folks I made a mistake, got another window in and managed to put a 3/4 screw into the frame and..... screwed through the window
But.... I might just tap it with the tig and see if I can close the holes up. Oops
Posted:
Sun Feb 09, 2020 12:34 pm
by featherliteCT1
Or maybe just fill hole with caulk and hide with black touch up paint?
Posted:
Mon Feb 10, 2020 1:04 pm
by McDave
Hey Big Dave,
S**t happens sometimes... a lot. No biggy. So I'm not sure of the camera angle there, but I think I see the drain slots at the top? IDK, but check that out. Drain at top would not be the preferred orientation. Slots made to let water out, not in.
McDave
Posted:
Mon Feb 10, 2020 1:32 pm
by dirtsailor2003
Black caulk and call it good! As McDave said if those are the weep holes they need to go facing down or you’ll get water inside.
Posted:
Mon Feb 10, 2020 9:52 pm
by BigDave_185
Well... testing out my old epoxy from a previous life
It’s old enough I had better check the chemical mix before I pour it on my trailer floor. Bottoms up as it goes. Hopefully in 12 hrs this cup is as hard as a rock.
Posted:
Tue Feb 11, 2020 10:28 am
by BigDave_185
As of last night at 11pm. The cup was hot enough I couldn’t hold it, the rolled out sample was still wet.
Fast forward to today at 7:00 the cup was hard as a rock
Posted:
by BigDave_185
Now to locate some primer and I’ll have a self leveling epoxy that is bullet proof.
