Cargo trailers with extra interior height
Postby jay87lx » Mon Nov 13, 2017 8:25 pm
It seems that many CT’s I am seeing are usually approx 72”. I was looking around for a CT with about a 7’ interior height.
For those of you that bought a v nose, about 7x14-16 and extra height
Where did you get it from?
In stock or ordered
Cost?
jay87lx
Re: Cargo trailers with extra interior height
Postby MtnDon » Mon Nov 13, 2017 8:36 pm
https://www.trailershowroom.com/
we ordered from a local seller who ordered a Lark with height. Trailer showroom uses different builders in different areas. Ours was a Lark from TX.
MtnDon
Images: 24
Postby flboy » Mon Nov 13, 2017 8:38 pm
I went with an extra 18 inches because I knew I wanted the loft bed accessible without unloading. I paid $35 per trailer ft (18ft) so it was $630 dollars extra. That works out to about $210 for each 6 inches of added height. All well worth the extra money.
I custom ordered my trailer with a bunch of extras to include the paint and chrome divider in addition to the fact I have never seen a 7.5ft. tall trailer on a lot already built. Sometimes you may see 6.5 ft.or 7ft. Lark will custom build, but a lot of others will also. Typically options are from a list of à la carte options. The only thing I ordered that was not on the "list" was the two tone paint with chrome divider strip and the design on the back side with gray and white. I had to draw that for them to get exactly what I wanted.
You should be able to do the same from most of the builders out there to get exactly what you want.
Mine is 7.5 ft tall inside. Here is a pic as I drove it away from the factory in Georgia: BTW.. I used the same folks that MtDon used, but my trailer was built in Douglas , Georgia.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby gbowman » Mon Nov 13, 2017 10:03 pm
I purchased a 7x7x16 foot from a trailer lot in Arkansas. I got it for about $4200. The 7ft interior height is well worth it.
It's a Covered Wagon. Loadngotrailers.com 870-426-4990. They custom build trailers but I believe they order the cargo trailers.
gbowman
Images: 7
Postby Padilen » Tue Nov 14, 2017 8:03 am
Many manufactures sell what they call a UTV or side by side hauler. These are usually 7' high interior as a minimum. Mine is an American Hauler 7x12x7. And as Don(FLboy) I wanted the height for loft/lift bed.
Padilen
Postby spacer » Tue Nov 14, 2017 11:17 am
While looking at a few cargo trailer manufacturers, it appears that quite a few have an options menu, including things like insulated floors, RV doors, and increased headroom.
spacer
Postby m.colley » Thu Nov 23, 2017 6:56 am
My 7x16 Cynergy came standard with a 75" ceiling, so I added 6 inches to the ceiling height.
Martin
m.colley
Images: 83
Postby CoventryKid » Thu Nov 23, 2017 10:04 am
Depends on the model, but my Neo NAVR had +6" option for 7' interior height.
Hope this helps.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Postby NotJammer » Wed Nov 29, 2017 5:13 pm
I bought my 2018 Legend 7x17 from Complete Trailers. My model is stock with 84" from floor to finished roof. http://www.completetrailers.com/trailer ... turecargo/ who retails Legend who does not sell to the public. http://www.legendmfginc.com/categories/ ... d-Trailers
It's way tall and if I could do it over I would have done 6" lower and 6' wide for less frontal area. I am 70" tall.
I also wish I had done steel wheels and not aluminum.
NotJammer
Postby featherliteCT1 » Wed Nov 29, 2017 7:52 pm
That 2018 Legend 7x17 from Complete Trailers is a VERY nice, VERY well built trailer!
featherliteCT1
Postby NotJammer » Fri Dec 01, 2017 12:34 pm
It sure is.
I tried to get them to spray closed cell foam underneath. No go. I may DIY as it's still very clean underneath.
NotJammer
