Sidewall Fan???
Re: Sidewall Fan???
Postby OCBINVA » Sun Dec 31, 2017 9:21 am
I wanna insulate. The thickness will be whatever gap I have after I figure out how to mount screwing studs to the ceiling. I hope to keep to nominal thicknesses with gaps filled with construction foam. I wanna be able to run tongue and groove the length of the roof.
Sent from my SM-N950U1 using Tapatalk
The Perpetual Tinkerer... The Goal: To keep Idle hands Busy, the Mind active, and the Muscles stretched...
Current Build: viewtopic.php?f=50&t=69709
Owner of a 66 Beeline, a 65 COX, and a 66 Apache and soon to be Micro Outdoorsman
OCBINVA
Images: 5
Re: Sidewall Fan???
Postby Hader » Sun Dec 31, 2017 9:40 am
Insulation thickness is a personal preference for how much R value you would want, and how much space you want to save.
The wall uprights and ceiling cross-members gave us 1 1/4" to work with. We settled for 1/2 insulation strips against the outer skin, and another 3/4' to cover. we then walled with 0.196" Luan screwed directly to the uprights and cross-members.
Some, and for good reason would add wood strips over and cross the uprights and cross-members to minimize thermal conductivity.
About halfway down here: viewtopic.php?f=42&t=67319 you'll see how we did ours.
Hader
Images: 84
Re: Sidewall Fan???
Postby OCBINVA » Sun Dec 31, 2017 9:57 am
I enjoyed your thread. The side walls will be 3/4 due to space restriction. The top will just depend based on how I figure out to mount the wood up there. The roof supports are c-channel with the opening facing down so I have no flat surface to screw into....I will need to brainstorm some...
OCBINVA
Images: 5
Re: Sidewall Fan???
Postby Hader » Sun Dec 31, 2017 10:05 am
OCBINVA wrote:The roof supports are c-channel with the opening facing down so I have no flat surface to screw into....
How about filling the c-channel with wood strips, screw trough the side of C-channel to keep strips in place, then attach your ceiling to the wood strips?
Hader
Images: 84
Re: Sidewall Fan???
Postby OCBINVA » Sun Dec 31, 2017 10:16 am
That's exactly what I have been thinking would work. The biggest issue will be drilling through 50yr old steel. Tough as nails. I might need to make a pattern and cut the wood with a profile so I can keep the arch ceiling.
My other thought was to run a board from side to side. It would make for a flat ceiling the the installation would be crazy easy....
OCBINVA
Images: 5
Re: Sidewall Fan???
Postby Hader » Sun Dec 31, 2017 10:35 am
OCBINVA wrote:
Hader wrote:
OCBINVA wrote: I might need to make a pattern and cut the wood with a profile so I can keep the arch ceiling.
This is how we created a cross-member (there wasn't one) with a curve to maintain the arch in the back of the trailer. gallery/image.php?album_id=4374&image_id=145412 3 (one over another) 1/2 strips of plywood
Look at the 2nd photo from the bottom here: gallery/image_page.php?album_id=4374&image_id=145412 That's how we insulated the front curves in the front.
Hader
Images: 84
Re: Sidewall Fan???
Postby OCBINVA » Sun Dec 31, 2017 11:04 am
Awesome!...that gave me some ideas
OCBINVA
Images: 5
Re: Sidewall Fan???
Postby McDave » Sun Dec 31, 2017 1:26 pm
Kerfs for curves....
McDave
McDave
Images: 412
Re: Sidewall Fan???
Postby OCBINVA » Sun Dec 31, 2017 1:56 pm
Well I was afraid of that...after demo there is significant rust through frame. It's not salvageable. The roof corners and fenders are good however. So the dilemma is to walk away, buy a 4 x 7 HF trailer and built it with these parts, or pay to have new frame built. The axle I have is good however. All in all I only have $100 into it...Image
OCBINVA
Images: 5
Re: Sidewall Fan???
Postby Hader » Sun Dec 31, 2017 5:41 pm
Sorry to hear that. Better luck next time!
Hader
Images: 84
